Hi Ken,
http://www.designers-guide.org/Analysis/sc-filters.pdfI was confused in page 22 (section 3.4) when I studied the above paper.
From the title of this section, I think unsmpldNoise means sources option and smpldNoise means timedomain option and these two analysis calculate the same output nodes (from netlist), right?
However in the picture12 (and also the section description), it seems the results were gotten from two different output nodes , one is unsampled node and the other is sampled node (with sample&hold?),
am I right?
I was confused about this. Can you clarify it for me?
Lunren
