Jul 18th, 2024, 3:28am
common mode of CML latch (Read 4779 times)
supermoment
Mar 27th, 2010, 7:30am
to design a high-speed CML latch (classical one), does the common-mode of the clock must be lower than data input common mode? (so that it can be completely turn off)
It works fine if the clock and data input common mode are same.
Pls advise and comment.
panditabupesh
Toronto
Re: common mode of CML latch
Reply #1 - Mar 27th, 2010, 3:32pm
Having lower input common mode means an extended swing at the output before the input transistor goes into triode region.
Bupesh
supermoment
Reply #2 - Mar 28th, 2010, 7:07am
The data common-mode is definitely near to vdd (vdd-swing/2).
I mean the clk input common mode. Shall it be same or much lower?
love_analog
Reply #3 - Apr 7th, 2010, 9:30pm
Assume the input to the data has CM=dx
Assume input to clock has CM=cx
Now if all the gates are at their common-mode, then we get the drain of the clock transistors as having a voltage = dx-vgs
whereas the clock transistors will have Vg=cx
So ideally you'd like clock ones to have cx<dx.
loveanalog.blogspot.com
The Power of Analog
supermoment
Reply #4 - May 4th, 2010, 7:04pm
Any problem if dx=cx? where the clk transistors are in triode mode since latch is a nonlinear circuit
love_analog
Reply #5 - May 5th, 2010, 12:39pm
Simulate it. I think you will see extra glitches in your output. But maybe you are okay with it.
The Power of Analog
