Jul 18th, 2024, 4:29am
SC BPF simualtions (Read 3934 times)
smalin
austria
SC BPF simualtions
Apr 08th, 2010, 1:28am
I am new on the forum. Hi to everybody. Hope you can help me.
I am trying to make set of simulations for BPF on the picture. I did PSS+PAC for transfer function - all works fine.
Now I want to do PSS+PSTB to check the stability of each opamp but here I have problems. results are strange. I placed two probes (one for each opamp) in marked places. Performed simualtions for each probe individually. results are not as expected.
How shoul the testbench look like to make proper simulations. Any hints.
Of course for this simulation input is connected to analog ground.
BR
View Profile smalin_pda   IP Logged
Frank Wiedmann
Munich, Germany
Re: SC BPF simualtions
Reply #1 - Apr 9th, 2010, 12:32am
Your probes are both in the local loop around the opamp (via the capacitor) and in the global loop, so the loop gain you are getting is the sum of the local and the global loop gains (and not only the local loop gain as you probably expected).
smalin
austria
Reply #2 - Apr 9th, 2010, 12:56am
Yes, you are right. To obtain the OL gain of opamps only I should open the global loop or keep it closed?
Where do you suggest to put probes and which loops should stay closed and which opend?
BR
Frank Wiedmann
Munich, Germany
Reply #3 - Apr 9th, 2010, 4:52am
Although your loop gain results may look unusual, you can still use them to examine the stability of your circuit. Please see http://www.designers-guide.org/Forum/YaBB.pl?num=1244840188 for some more details.
smalin
austria
Reply #4 - Apr 9th, 2010, 8:48am
Below I place Nyquist diagramms. Can you help me to interpreat results?
I have to go in details with stability criterion during weekend to understand this better.
Any way thanks for your help. It is always for me to learn something new.
BR
Frank Wiedmann
Munich, Germany
Reply #5 - Apr 10th, 2010, 1:30am
Your plots are a little hard to interpret but to me it looks like the curve encircles -1 but not +1. So, if your plot shows the loop gain as calculated by the pstb analysis, for which the critical point is +1 due to the sign inversion (see replies #3 and #5 of http://www.designers-guide.org/Forum/YaBB.pl?num=1244840188), there would be no encirclement.
