Jul 17th, 2024, 10:17am
is possible to write model for piecewise linear source (Read 10161 times)
seefree
Apr 09th, 2010, 6:36am
Hi there,
Is it possible to write a pwl voltage source model in veriloga? I want to use a pwl voltage source with an enable signal, whenever the enable is high, the pwl source starts to work. The problem is, I don't know how to define the number of pairs for the model for different simulations.
Boris Troyanovsky
Re: is possible to write model for piecewise linear source
Reply #1 - Apr 9th, 2010, 10:32am
Here's a Verilog-A pwl implementation using arrays for time/voltage input. It doesn't have the enable feature (not sure what the goal there would be), but you should be able to add that in.
`include "disciplines.vams"
module pwl(out);
output out;
electrical out;
parameter integer N = 1 from [2:inf);parameter real t[1:N] = {N{0}};
parameter real y[1:N] = {N{0}};
analog begin : blk
integer nxt_i;
real yp, tp, slope;
integer err;
        @(initial_step) begin
                nxt_i = 1;
                yp = y[1];
                tp = 0.0;
        @(timer(t[nxt_i])) begin
                yp = y[nxt_i];
                tp = t[nxt_i];
                if(nxt_i < N) begin
                        nxt_i = nxt_i + 1;
                        if(t[nxt_i] - tp <= 0) begin
                                err = 1;
                                $debug("Non monotonic time sequence: t[%d] == %e, t[%d] == %e", nxt_i-1, tp, nxt_i, t[nxt_i]);
                                $finish;
                        if(!err)
                                slope = (y[nxt_i] - yp)/(t[nxt_i] - tp);
        if(!err)
                V(out) <+ yp + slope*($realtime - tp);
Boris Troyanovsky
Reply #2 - Apr 9th, 2010, 10:40am
... and here's one if you prefer string input for the pwl (e.g., pwl="0.0, 0.0, 0.5, 1.1, 1.0, -1.1,..."). It does use the non-standard string .len() operator from System-Verilog, and so may not be suitable for your application.
module strpwl(p, n);
   electrical p, n;
   inout p, n;
   parameter string pwl = "";
   parameter        dcval = 0.0;
   analog function real scanval;
      input s;
      inout pos;
      string s;
      integer pos;
      integer ipos;
      string  valstr;
      begin
         ipos = pos;
         while(pos < s.len() && s.substr(pos, pos) != ",")
           pos = pos+1;
         valstr = s.substr(ipos, pos-1);
         if(1 == $sscanf(valstr, "%g", scanval))
           pos = pos+1;
         else
           pos = -1;  // Error indicator
   endfunction
   integer pos = 0;
   real    tnext, vnext;
   real    tprev = 0.0;
   real    vprev = dcval;
   real    slope;
   integer err;
   analog initial begin : blk
      real retVal;
      tprev = 0.0;
      vprev = dcval;
      tnext = scanval(pwl, pos);
      vnext = scanval(pwl, pos);
      if (tnext-tprev != 0.0)
          slope = (vnext - vprev)/(tnext - tprev);
      $strobe(tnext, vnext);
   analog begin
      @(timer(tnext)) begin
         tprev = tnext;
         vprev = vnext;
         if(pos > 0)
           begin
              if(tnext - tprev <= 0) begin
                 err = 1;
                 $debug("Non monotonic time sequence.");
                 $finish;
              if(!err)
      if(!err)
        V(p, n) <+ vprev + slope*($abstime - tprev);
seefree
Reply #3 - Apr 9th, 2010, 10:51am
I will add the enable pin and try the models.
Appreciate your help
seefree
Reply #4 - Apr 14th, 2010, 11:25am
This model works in spectre. However, if I run it in ams, I got the ncvlog error message complaining phrase:
   parameter real t[1:N] = {0,1};
It says "In Affirma-AMS, parameter array declaration is not supported"
How can I solve this problem?
Boris Troyanovsky wrote on Apr 9th, 2010, 10:32am:
module pwl(out);
output out;
electrical out;
analog begin : blk
integer nxt_i;
real yp, tp, slope;
integer err;
                nxt_i = 1;
                yp = y[1];
                tp = 0.0;
                yp = y[nxt_i];
                tp = t[nxt_i];
                if(nxt_i < N) begin
                        nxt_i = nxt_i + 1;
                                err = 1;
                                $finish;
                        if(!err)
        if(!err)
patrick
Santa Rosa, CA.
Reply #5 - Apr 14th, 2010, 1:42pm
I'm not sure if this would work for you but you could put the pwl breakpoints into a file and use $table_model in the module body to read them in.
Patrick
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #6 - May 17th, 2010, 4:11am
Another approach is to create an array variable and assign it a value in an initial step:
module test (a, b);
  parameter integer npairs = 4;
  inout a, b;
  electrical a, b;
  real times[0:npairs-1], values[0:npairs-1];
  integer i;
  analog begin
      times[0] = 0;    values[0] = 0;
      times[1] = 1n;   values[1] = 0.25;
      times[2] = 2n;   values[2] = 0.5;
      times[3] = 5n;   values[3] = 0.75;
    if (times[i+1] < $abstime) begin
      i = i + 1;
      $discontinuity(1);
    V(a, b) <+ (values[i+1] - values[i]) * ($abstime - times[i])/(times[i+1] - times[i]) + values[i];
endmodule // test
But first try to use Patrick's suggestion: it is much simpler and more flexible.
Cheers,
Marq
