Aug 16th, 2024, 1:01pm
How to write a time amplifier? (Read 3044 times)
5gougou
Apr 18th, 2010, 7:44pm
How to write a 2x time amplifier with Verilog-A?
This is a model with two input signals with a time interval of T1, and two outputs with time interval 2*T1.
Does anyone knows?
Thanks very much~ Smiley
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: How to write a time amplifier?
Reply #1 - Apr 19th, 2010, 2:01am
What do you mean with a time interval? Is there a delay between the two signals or a phase difference? It is unclear to me what the circuit is supposed to do. Would it be possible to explain or to point to a site where such a function is explained.
Marq
5gougou
Reply #2 - Apr 19th, 2010, 3:51am
The time interval means a time delay between the two signals.
This circuit is going to amplify  that delay.
Sorry for the unclear statement.
Please contact if any further confusion. Or you may like to see that circuit in this file:
http://www.staff.ncl.ac.uk/david.kinniment/Research/papers/ElectLett2002.PDF
Thanks very much Smiley
Marq Kole
Hmmm. That's
weird...
Reply #3 - Apr 19th, 2010, 7:47am
I would do something like this:
module time_diff_amp (z, y, a, b);
input a, b;
output z, y;
electrical z, y, a, b;
parameter real thresh = 0.5;
parameter real tgain = 3.0;
parameter real td = 10p;
parameter real tr = 20p;
real out, last_cross_a, last_cross_b, delta_t;
integer sign_t;
analog begin
  last_cross_a = last_crossing(V(a) - thresh, +1);
  last_cross_b = last_crossing(V(b) - thresh, +1);
  @(cross(V(a) - thresh, -1) or
	cross(V(b) - thresh, -1)) begin
    last_cross_a = 0;
    last_cross_b = 0;
    out = 0;
  @(cross(V(a) - thresh, +1))
    if (last_cross_a > 0 && last_cross_b > 0) begin
	delta_t = tgain * abs(last_cross_a - last_cross_b)
	sign_t = (last_cross_a >= last_cross_b);
	out = 1;
  @(cross(V(b) - thresh, +1))
	delta_t = tgain * abs(last_cross_a - last_cross_b);
	out = 1;
  V(z) <+ transition(out, td + sign_t *delta_t, tr);
  V(y) <+ transition(out, td + (1 - sign_t) *delta_t, tr);
endmodule // time_diff_amp
5gougou
Reply #4 - Apr 22nd, 2010, 12:23am
This is the very code I want.
Thank you very much!
Ruili Smiley
