Oct 5th, 2026, 11:56am
Equation in verilogA (Read 3759 times)
princemahmmod
Apr 19th, 2010, 9:21am
Can anyone help me how to write in verilogA following equation???
y= x/ (a*exp(-0.5*((x-b)/c)^2)) +d
Your help would be greatly appreciated
Re: Equation in verilogA
Reply #1 - Apr 20th, 2010, 12:30am
I didn't check whether this equation made any sense, and I didn't set the parameter values to anything meaningful - I just wrote it to illustrate the syntax:
`include "disciplines.vams"
module equation(y,x);
output y;
input x;
electrical x,y;
parameter real a=1.0;
parameter real b=1.0;
parameter real c=1.0;
parameter real d=1.0;
analog begin
  V(y) <+ V(x)/(a*exp(-0.5*pow((V(x)-b)/c,2)))+d;
princemahmmod
Reply #2 - Apr 20th, 2010, 7:57am
Thank you so much....Its work...fine...Though I am changing the parameters...but I got your syntax...!!
