Jul 18th, 2024, 1:15pm
AGC loop stability simulation in Cadence (Read 2666 times)
Ruritania
Canada
Apr 30th, 2010, 11:55am
I'm trying to use Spectre to simulate the loop stability of the AGC shown below.
Since the loop can only work properly when a signal (sine wave) is presented at vin, is there any particular way to simulate the loop stability in such cases?
I tried PSS+PSTB, but the outputs are just two flat lines (phase margin & gain margin), which does not make any sense.
Thanks.
Re: AGC loop stability simulation in Cadence
Reply #1 - Apr 30th, 2010, 11:52pm
PSTB is no more than PAC of sideband=0.
Where do you insert probe ?
Show me your netlist regarding signal(power) sources and PSS/PSTB statement.
http://www.designers-guide.org/Forum/YaBB.pl?num=1217939784
http://www.designers-guide.org/Forum/YaBB.pl?num=1265101150
buddypoor
Bremen, Germany
Reply #2 - May 1st, 2010, 1:47am
Ruritania wrote on Apr 30th, 2010, 11:55am:
Thanks.
Hi RURITANIA,
I do not use SPECTRE. However, some general comments are to be given - independent on the simulator engine used.
Since the AGC loop is inherently non-linear it must be linearized before the rules of linear circuit theory may be applied (loop gain, phase margin,...)
At first, what kind of voltage controlled amplifier are you using?
I suppose, it will be "linear-in-dB" , correct?
In this case, you have to use the log function to linearize with the result that input/output/reference signals now are in dBV.
At second, you have to realize that the circuit only responds to changes of the input signal. With this in mind you can create a linearized block diagram in the s-domain which leads to the following loop gain expression:
Loop gain AL=-Kd*Kc*Fd*Fr  with
Kd=Vref*2.3/20 in V/dB ;
Kc=Ko*20/2.3 in dB/V  (Ko=sensitivity of gain control in exp(Ko*Vcontrol) ;
Fd=transfer function of level detector
Fr=Transfer function of controller/filter (smoothing of control voltage)
This model applies only for an amplifier which is "linear-in-dB" . The model does NOT depend on the level of inpiut power, but the variations of the input signal are limited to app. +- 1.5 dB (validity of the linear model).
Hope this helps.
Good luck and regards.
Ruritania
Canada
Reply #3 - May 3rd, 2010, 7:56am
pancho_hideboo wrote on Apr 30th, 2010, 11:52pm:
Thanks for your reply.
I agree that PSTB is no more than PAC of SB=0, but is there any issue to run it with PSTB?
I inserted the probe btwn the loop filter and VGA control input (Vc, in the pix of my last post).
Thanks.
Ruritania
Canada
Reply #4 - May 3rd, 2010, 8:16am
buddypoor wrote on May 1st, 2010, 1:47am:
Hi RURITANIA,
Hope this helps.
Hi buddypoor,
Thanks for your kind reply.
You raised a really important point that the previously mentioned stability theory can only be applied to the linearized circuits or components. Yes, my VGA is "linear-in-dB," and I did build the similar models in ahdl. But as you may know, the models are just rough estimates of the real circuits, and most likely you cannot include all of the poles/zeros in the models. Eventually you need to verify the stability in the REAL circuits.
Any comments on how to verify the stability of such loops with non-linear circuits in simulation?
Thanks.
Reply #5 - May 3rd, 2010, 8:21am
Ruritania wrote on May 3rd, 2010, 7:56am:
There is a problem in slave small signal analyses such as PAC, PXF, Pnoise, PSTB, PSP subjected to master PSS of Cadence Spectre for BSIM3 model use.
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1200305082
http://www.designers-guide.org/Forum/YaBB.pl?num=1214897800
Try to use other vendor's simulator or use newest Cadence Spectre(MMSIM).
Ruritania wrote on May 3rd, 2010, 8:16am:
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1268385779
http://www.edaboard.com/ftopic272570.html
http://www.designers-guide.org/Forum/YaBB.pl?num=1243078889
http://www.designers-guide.org/Forum/YaBB.pl?num=1255834027
buddypoor
Bremen, Germany
Reply #6 - May 3rd, 2010, 8:33am
What do you mean with "real circuits" ? Measurements rather than simulation?  For my opinion, only dominant poles/zeros are important for stability checks.
Ruritania
Canada
Reply #7 - May 3rd, 2010, 8:36am
pancho_hideboo wrote on May 3rd, 2010, 7:59am:
See the followings.
I just checked the log, the version is 6.2.1.390, 28 oct 2008. Does this version have the mentioned issue?
Thanks.
Reply #8 - May 3rd, 2010, 8:38am
Ruritania wrote on May 3rd, 2010, 8:36am:
I don't know.
Expect answer from Cadence guys.
Ruritania
Canada
Reply #9 - May 3rd, 2010, 8:45am
[/quote]
[/quote]
Hi buddypoor,
For "real circuits," I referred to the transistor level. What I meant is that, even if you successfully verified the loop stability in the linearized model level, you may still want to check the loop stability in the transistor level in the end of the day.
Thanks.
buddypoor
Bremen, Germany
Reply #10 - May 4th, 2010, 12:13am
Ruritania wrote on May 3rd, 2010, 8:45am:
Hi buddypoor,
Thanks.
Of course, simulation can give you only a - more or less - rough estimate concerning circuit behaviour. But - that's a lot!
And, of course, you have to verify the results based on "real circuits". In particular, when you have simulated a linear model of a non-linear circuit. However, certain parameters (e.g. stability margins) are defined for linear systems only.
love_analog
Reply #11 - May 18th, 2010, 9:49pm
Buddypoor,
In your Origianl post, what is Kd and Kc.
loveanalog.blogspot.com
The Power of Analog
buddypoor
Bremen, Germany
Reply #12 - May 22nd, 2010, 8:22am
love_analog wrote on May 18th, 2010, 9:49pm:
Buddypoor,
It is defined in my first posting May 1st.
