Jul 16th, 2024, 4:01pm
Ring oscillator Phase noise (Read 2529 times)
raja.cedt
May 04th, 2010, 7:40am
hi,
  i have designed a ring oscillator for 2.4g, i got phase noise around 98dbc/hz..i found major contribution from V to I converter? is it my observation correct if so could you please explain reason or  please direct me towards good reference
Rajasekhar.
Re: Ring oscillator Phase noise
Reply #1 - May 4th, 2010, 7:07pm
It will be one of many contributors.
What's your circuit architecture?
raja.cedt
Reply #2 - May 4th, 2010, 8:03pm
hi,
 the delay cell has been used here is current steering  based inverters, so in this i found  V to I is major....
Rajasekhar.
love_analog
Reply #3 - May 5th, 2010, 12:37pm
If you can upload a schematic that is better.
Remember in LC VCO, the bias current is a major contributor. We put RC filter to remove the bias current contribution.
So what you are seeing is not unreasonable, provided we understand your schematics better.
loveanalog.blogspot.com
The Power of Analog
