Jul 16th, 2024, 6:45pm
3MHz rectifier (Read 2017 times)
joc
3MHz rectifier
May 05th, 2010, 10:09am
Hi there!
I need to rectify a 3MHz signal, with 30mVpp. I tried with an opamp LM318, but the bandwidth is not enough. I tried with a transistor 2n3904, in a common emiter configuration but I almost got an unity gain. I did this on a protoboard. Can I still use protoboard at this frequencies?. Any advice will be appreciated.
Thanks Shocked
RFICDUDE
Re: 3MHz rectifier
Reply #1 - May 15th, 2010, 4:58pm
Are you trying to demodulate a 3MHz signal, or are you trying to rectify a 3MHz carrier to perform power conversion (or are you trying to do something completely different)?
rfcooltools.com
Re: 3MHz rectifier
Reply #2 - May 17th, 2010, 10:35am
joc,
use two npns hooked as a differential pair tie one base to a voltage reference (AC short)  then apply your 3 MHz signal to the other base (bias it correctly of course)  your rectified signal will be at the emitter.
2n3904 will work at these frequencies.
Can I still use protoboard at this frequencies?  Probably not an issue unless your trace is a meter or more.
Jeremy
