Jul 17th, 2024, 10:42am
random number generation (Read 2056 times)
rajdeep
UK
May 07th, 2010, 3:52am
Hi All,
I was trying to use a $rdist_uniform to generate random numbers. The code portion is:
@(cross(V(clk) - fullscale/2.0,-1))
	  begin
		    th = $rdist_uniform(seed, lo, hi);
	  V(out) <+ th;
Seed has been defined as 1. I thought it would generate a random voltage at every negative edge of clk. But it does not do that!! Im running it using Cadence Spectre.
Any help?
Thanks!
Rajdeep
rajdeep
UK
Re: random number generation
Reply #1 - May 7th, 2010, 4:28am
Sorry! I got the problem now! Huh
It was the seed variable. I made it hard coded!! I didnt realize this variable gets updated
internally!!
Rajdeep
