I can't find out any design issue in your post
again.
Your question is no more than very easy usage of specific vendor's tool.
I couldn't find out any design issue in
http://www.designers-guide.org/Forum/YaBB.pl?num=1248361147Your descriptions are always very poor.
What do you mean by "p1_tone" ?
Use captal letter and small letter correctly.
Almost all simulator are case sensitive.
The followings are general notes for you.
Always describe correct tool's name and vendor's name which you use as tool or simulator.- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
Describe in detail with using correct terminologies.- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
