Jul 17th, 2024, 8:17am
Multi-dimensional arrays in Verilog-AMS (Read 2622 times)
mehregan
Minnesota
May 07th, 2010, 10:37am
I would like to model a volumetric space by breaking it up into smaller volumes or mesh's and modeling each space using an R-C combination.  I would like the number of mesh's to be set by the user as a parameter on the model and the values of Resistance/Capacitance in each mesh would need to vary from its adjacent neighbor.   I know about the genvar function in AMS which would allow me to index a 1-dimensional array.  I also know that Verilog 2001 supports multi-dimensional arrays.   However there seems to be some limitations of using multi-dimensional arrays on analog nodes in AMS.
module saline1 (INOUT1, INOUT2 );
  inout INOUT1, INOUT2
  electrical INOUT1, INOUT2;
  parameter integer slices = 3;
  wire [0:slices] mesh [0:slices] [0:slices];
  genvar i, j, k;
  for (i=0; i<slices;i=i+1) begin
     for (j=0; j<slices;j=j+1) begin
        for (k=0; k<slices;k=k+1) begin
         resistor  #(.r(10)) R123 (mesh[i][j][k], mesh[i+1][j+1][k+1]);
In this model however, AMS used the VHDL model for the resistor instead of the analog Spectre version.  Not sure why.  In my version of AMS simulator (AMS Designer) I cannot specify the net mesh as type "electrical".  I had to use type "wire".  This seems like a limitation of AMS?  This also seems to preclude me from defining the resistor behaviorally within the analog begin - end as  an equation: V() <+ I()/R;
I'm just curious if anyone has ever done any kind of multi-dimensional AMS where the multi-dimensional array is an analog electrical net.
- Rob
