Jul 16th, 2024, 10:24pm
Does overlap capacitance Cgdovl factor into the Cgd and Cgsovl factor into Cgs? (Read 9037 times)
supermoment
May 09th, 2010, 8:34pm
Using spectre simulator to extract capacitance like Cgs, Cdg, Cdd, etc, by using OP command.
bsim3v3 model.
Re: Does overlap capacitance Cgdovl factor into the Cgd and Cgsovl factor into Cgs?
Reply #1 - May 10th, 2010, 3:54am
Did you try reading the manual?  Or setting up a simple experiment?
I just set up a simple experiment, setting cgso=0.3, and I saw that the op-pt value cgs got large, meaning it is included.  There are other op-pt values (cgsbi, cgdbi) that claim to be intrinsic parts.
supermoment
Reply #2 - May 11th, 2010, 7:06am
I believe you use HSPICE to extract it. But I do not have HSPICE!
I only can use spectre.
It does not have cgsbi, cgdbi in the OP list
Now i suspect Cgs does not include overlap cap since it is small .. u could see my another thread in http://www.designers-guide.org/Forum/YaBB.pl?num=1273302986/7#7
Could you do a comparison with my Cgs value? see the link above.
Thank you!
Reply #3 - May 17th, 2010, 5:21am
I don't see a modelcard in the other thread, so I can't do a comparison.
If you have the modelcard,
model nmos bsim3v3 ...
then make a copy
model nmos_alt bsim3v3 ...
and change the value of CGSO.  Then see if CGS changes.
What version of Spectre are you using?
supermoment
Reply #4 - May 17th, 2010, 5:33am
I am using IC5141.
Spectre from MMSIM71
I am not sure I could post the transistor bsim3v3 model...
Reply #5 - May 18th, 2010, 8:14am
I don't need to you to post it.  I want to you look at it and see if there is a CGSO value specified.
If so, then change that value by a factor of 1000, and see what happens to the operating-point information that is reported.
supermoment
Reply #6 - Jun 2nd, 2010, 10:36pm
i hacked cgso bsim3v3 in the model file.
But the cgs remains the same.
so it is not included?
supermoment
Reply #7 - Jun 2nd, 2010, 11:01pm
again, i obtained the cgsovl value from OP after hacking the cgso
I found that hacking cgso in the model file does not change the cgsovl & Cgs value at all!! (i am sure that i hack the correct model file and session)
it puzzles me!
supermoment
Reply #8 - Jun 2nd, 2010, 11:05pm
After reading chapter4 from http://www-device.eecs.berkeley.edu/~bsim3/get.html
it states that:
Gate Overlap Charge
In the above expressions, if CGS0 and CGD0 (the overlap capacitances
between the gate and the heavily doped source/drain regions, respectively)
are not given, they are calculated according to the following
CGS0 = (DLC*Cox) - CGS1 (if DLC is given and DLC > 0)
I have checked the model file, it does contain DLC & Cgsl parameters.
How do i know the simulator will use which one?? the given cgso or the calculated cgso from dlc & cgsl..
Reply #9 - Jun 4th, 2010, 3:52am
Your quote from the BSIM3 manual implicitly states that if CGSO is given, then that specified value will be used.
I wonder, though: are you specifying cgs0 or cgso ?  I noticed "CGS1" instead of "CGSL" in your calculation, and then when I copied&pasted your "CGS0" I could tell that it was a zero instead of the letter O.
supermoment
Reply #10 - Jun 11th, 2010, 6:20am
checked. It is really CGSl (L) in my foundry library. While in the Bsim3v3 document it is CGS1 (one)
Still puzzles me... Whether the library got problem or not...
since it gave me the fixed value after hacking
