Jul 17th, 2024, 6:41am
Precision Poly Resistor - # of contacts (Read 6601 times)
AnalogDE
May 10th, 2010, 10:30am
I am laying out a precision poly resistor... I would like to have the most flexibility in selecting tap points so I have filled the entire length with contacts (each contact is 0.24um apart) with overall length 300um so more than 1000 taps.  Will having so many taps alter the R/sq of the poly ?
wave
Re: Precision Poly Resistor - # of contacts
Reply #1 - May 10th, 2010, 7:13pm
Are you planning on spinning metal masks until you get lucky?
And hoping the process never shifts?
I would think analog trim links would be easier to get in somehow.
I'm hopeful there is a good story here.
Cool
Reply #2 - May 10th, 2010, 8:48pm
"precision poly resistor"
No such thing.
+/- 20% variance on process needs to be accounted for.
even if you are trying to get matched resistors you will have matching errors and contact resistance vaires widely.
What is the problem you are trying to solve with this magic resistor? There are probably better ways to solve the problem.
AnalogDE
Reply #3 - May 11th, 2010, 10:42am
This is my nifty VDD/2 rail splitter reference/resistor divider.  It's a poly resistor between VDD and GND with a large NMOS switch at the bottom.
I want to have the flexibility to get right at the 1/2-way point in terms of voltage and cancellating out any systematic offsets (say from package routing, for example, or anything else).  I really only need enough tap points around the middle, but since this is a matched resistor I need to have the contacts over the entire length.  I'm worried about messing up my R/sq or anything else by having so many contacts over it.
AnalogDE
Reply #4 - May 11th, 2010, 10:44am
Also, I'm not changing the length, just the tap point on the divider.  Contact resistance doesn't matter because there is no DC current flowing through the contacts/tap point.
love_analog
Reply #5 - May 14th, 2010, 4:16pm
why don't you just put 2 equal resistors between Vdd and ground and take the mid-point as Vdd/2.
loveanalog.blogspot.com
The Power of Analog
Reply #6 - May 19th, 2010, 4:39am
Hi jiesteve,
What are you working on? A resistor ladder or just a divide-by-2?
What type of resistor do you use? Poly with silicide or without silicide?
What is the resistance of the all resistors?
What's the accuracy/error you are seeking? If you need a 10+ bit DAC, there is an good example in VERMA and RAZAVI's paper. JSSC Nov. 2009.
Yawei
AnalogDE
Reply #7 - May 19th, 2010, 9:19am
It's just a divide-by-2 with metal options to adjust the tap point.
We're using poly with silicide (~16ohms/sq typical)
Total resistance is 1.6kohm
I need something like 10-11bit accuracy
rf-design
Reiner Franke
Reply #8 - May 19th, 2010, 6:43pm
Taking your numbers
16 Ohms/sq & 1.6KOhm and 11 Bit accuracy of the 0.5 divider ratio makes 50sq+50sq but the tap should be stepped at 50/2048 sq =1/40 sq
You should have a very wide poly to make tap adjustments by 1/40sq with single contacts. I would also layout two interwinded snakes of poly because otherwise the poly and silicide thickness gradient are violating 10-11bit. If you want to have a selectable tap by less than a contact size I propose to use a second resistor connected at 0.525 and 0.475 positions and having a higher resistor and being longer to place the taps.
Reply #9 - May 20th, 2010, 8:48am
Hi Jiesteve,
What's Reiner is correct. It seems very difficult to fullfil your job using the low sheet resistance poly resistor only.
Yawei
