Hi jiesteve,
What are you working on? A resistor ladder or just a divide-by-2?
What type of resistor do you use? Poly with silicide or without silicide?
What is the resistance of the all resistors?
What's the accuracy/error you are seeking? If you need a 10+ bit DAC, there is an good example in VERMA and RAZAVI's paper. JSSC Nov. 2009.
Best Regards, Yawei
