Jul 18th, 2024, 11:19am
Mathematical calculations in the offset simulation of the comparator (Read 3347 times)
M.K.
May 11th, 2010, 10:45pm
I have a question regarding offset simulation of comparators method reported by Achim Graupner.
I am wondering if it is possible to simply measure the difference between the input ramp (at output transition point) and reference (threshold) voltage and consider this variable as offset voltage. Then by using Monte Carlo results for this variable, mean and variance of the offset can be obtained.
If so why we need those mathematical post processing?
Thanks in advance.
View Profile M.K.   IP Logged
AnalogDE
Re: Mathematical calculations in the offset simulation of the comparator
Reply #1 - May 17th, 2010, 4:31pm
What you describe sounds more like a DC offset measurement -- that's fine for DC.  but if you want to include transient effects (hysteresis, for example) then the method you describe will be optimistic.
M.K.
Reply #2 - May 17th, 2010, 7:37pm
Thanks for your reply.
I agree that DC simulation could not be a correct way and a better way is doing transient analysis. What I described is exatly the same method as in paper (Doing transient analysis by applying an increasing step and running Monte Carlo on this transient analysis). My question is on the last step where mean and variance is calculated using mathematical equations.
Why these parameters cannot directly obtained from the results of Monte Carlo? The only reason I can think about is cases where we have more than one transition in either rising or falling directions. In that case the threshold voltage is undefined.
AnalogDE
Reply #3 - May 18th, 2010, 9:29am
There is post-processing because you need to run a monte carlo for each input.
For example if you have your threshold at 0mV differential you would run a bunch of MC simulations around 0mV Vin (-2mV, -1mV, 0mV, +1mV, +2mV), etc.  Each MC simulation gives you the number of times your comparator outputs a 1 (or 0).  From that, you can fit a line to extract the stddev of the offset.
Unless there's a way you can loop the MC run in your simulator you will have to do some post-processing.  (If you know how to do this in eldo, I'd be interested.  I had to hack together my own perl script to do it.)
M.K.
Reply #4 - May 20th, 2010, 11:52pm
Thanks for reply.
Actually I am doing it in another way. In each MC run, during transient analysis, I am reseting my comparator and applying first voltage (e.g. 0mv) and reading the output (e.g. 1) and then reseting again and applying the next voltage (e.g. 1mV) and waiting for output (e.g. 1), .... during this transient analysis I can find the switching threshold of the comparator for this MC run. After completing the whole MC runs, I have a distribution of the switching threshold of the comparator.
(Note: My comparator should be reset between two consecutive inputs)
