Jul 16th, 2024, 1:43pm
RF mixer (Read 1255 times)
delinqfour
RF mixer
May 11th, 2010, 11:27pm
hi.
my question is pretty basic.  i need to know what will happen to the mixer output
1) if i ground the RF input.  will i be getting my LO at the output.
2) if i ground my LO input. will my output simply be the RF input.
thanks
Re: RF mixer
Reply #1 - May 12th, 2010, 5:00am
I assume actual RF mixer which is not ideal four quadrant multiplier and does have mismatch.
delinqfour wrote on May 11th, 2010, 11:27pm:
Yes.
Yes.
aaron_do
Re: RF mixer
Reply #2 - May 12th, 2010, 5:17am
It depends on the design. In a balanced design (Gilbert Cell), ideally you will get nothing for both cases, but in practice there will be some unwanted feed-through.
A Kumar R
India
Re: RF mixer
Reply #3 - May 13th, 2010, 5:27am
hi..
@aaron_do
i agree with aaron_do, as far as the active mixers are concerned, if we do not supply any input to LO or RF ports, ideally we will get nothing at the output. i think that is the definition of a doubly balanced mixer. this is not the case in singly balanced types.
correct me if am wrong..
thank you...
Re: RF mixer
Reply #4 - May 13th, 2010, 5:39am
A Kumar R wrote on May 13th, 2010, 5:27am:
Observe output of actual mixer by actual instruments not by EDA-Tool-Play.
We can use Gilbert-Cell as Voltage-Controled-Gain-Amplifier, but we can never make output zero in actual circuits.
At most, -40dB~-60dB.
delinqfour
Re: RF mixer
Reply #5 - May 13th, 2010, 6:54pm
hi all
my question is if we only put only one of them on (either RF or LO), and the other grounded (either LO or RF). Just wondering what the output will be
a gilbert cell mixer needs to be driven by LO, am i right? so if i ground the LO input, i will be turning off a couple of transistors in the circuit which makes the output port open, so ideally i get nothing at the output, correct?
but if i ground the RF input, same thing happens
am in the right track?
Re: RF mixer
Reply #6 - May 14th, 2010, 2:18am
Gilbert Cell Mixer is a "four quadrant multiplier" for small input level ideally.
delinqfour wrote on May 13th, 2010, 6:54pm:
Right.
Correct if it could be very ideal, although the output ports are not open state.
Yes, if it could be very ideal.
Again, observe output of actual mixer by actual instruments not by EDA-Tool-Play.
