Marq Kole
![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif)
![](https://designers-guide.org/forum/avatars/devil.gif)
Hmmm. That's weird...
Eindhoven, The Netherlands
Hi Thomas,
The general approach of phase-domain modeling can be applied, but not directly using the models from the paper. If you read through it there are a number of assumptions and modeling choices that make it operate correctly only in lock. However, if you rewrite the VCO, divider and PFD/CP models such that they take both phase and (angular) frequency as signals you should be able to get a phase-domain model that shows locking behavior at very high simulation speed.
Cheers, Marq
