Jul 17th, 2024, 6:38am
the cp current ratio between FD/CP and PD/CP in CDR. (Read 1534 times)
ipmsn5
China
May 18th, 2010, 2:41am
Dear all,
I start the cdr  2.5gps circuit now, would you please give me a charge pump current  ratio between  freq detector CP and  phase detector CP?
By the way, I see some papers show that the off chip filter is better,  do you think so?
Smiley
thanks for your help.
love_analog
Re: the cp current ratio between FD/CP and PD/CP in CDR.
Reply #1 - May 31st, 2010, 7:42am
Write the equations for the loop Bw and damping. There is no one answer. Typically you want much larger BW for the FD loop to keep acquisiton time low. For PD one, Jtol determines your BW
loveanalog.blogspot.com
The Power of Analog
