xuhaoz wrote on May 29th, 2010, 8:13am:Hi, if I use pss in cadence
What do you mean by "
pss in cadence" ?
We can use many simulators such as HSPICE, BDA's Analog FastSPICE RF, ADSsim and GoldenGate in Cadence ADE.
Do you mean "PSS in Cadence Spectre" ?
If there is a common divisor frequency in {fvco +/- 0.5*fvco, fvco +/-
52MHz, fvco/2, fvco/4, fvco/60}, you might be able to use PSS which is Large Signal Steady State Analysis based on one fundamental frequency.
If "fvco +/-
52MHz" are not included in frequencies or you treat 52MHz signal as small signal, a common divisor frequency is fvco/60.
Again there are two options for treatment of 52MHz signal.
How do you treat 52MHz signal, small or large ?
Do you understand meaning of "small signal" and "large signal" in simulation ?
Again surely see http://www.designers-guide.org/Forum/YaBB.pl?num=1204880225/5#5The followings are general notes for you.
Always describe correct tool's name and vendor's name which you use as tool or simulator.- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
There are many simulators which have analyses called as PSS, PAC and Pnoise.-
Describe in detail with using correct terminologies.- Warnigns are different from Errors.
- ADS is not name of simulator.
There is no tool which name is Cadence.- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
