Jul 17th, 2024, 2:21am
Low Pass Filter Problem . Expert advice needed. (Read 3755 times)
Digital
May 20th, 2010, 1:11am
I am trying to remove the 1st and 2nd harmonic from a transmitter I have designed in the 433mhz band. It puts out 17dbm.. The transmitter is all surface mount based around the SX1230 chip.
Ive built two 5 element low pass filters with SMA in and out connectors and tested them with a spectrum analyzer with tracking gen. Both perform well with less than 1 db of insertion attenuation at 433mhz and around 25 db at 860mhz.
The problem is when I test them with my transmitter there seems to be no visible reduction in the harmonics when viewed with the spec ann.
This makes absolutely no sense to me infact it even sounds ridiculous.
Has anyone got any ideas of where I’m going wrong.???
wave
Re: Low Pass Filter Problem . Expert advice needed.
Reply #1 - May 20th, 2010, 1:20pm
Can you add some more details:
Is the 433M a carrier or the signal as well (ie baseband frequency?)
What is the BW of the 2 LPF by spec and confirmed by measurement on network analyzer?
Do all the impedances match when connected together in the system?  ie 50 ohm terminations?
What do you expect to transmit at?
A 1st harmonic is the fundamental, so perhaps you actually mean the 2nd and 3rd harmnonics?  That would transmit more of sinewave as opposed to a squarewave.
cheers!
Wave
Digital wrote on May 20th, 2010, 1:11am:
Digital
Reply #2 - May 20th, 2010, 6:12pm
Wave..
1st harmonic is the fundamental.. Cheesy
That would transmit more of sinewave as opposed to a squarewave.   Grin
Sorry but i need expert advice
Reply #3 - May 21st, 2010, 2:42am
To make LC filter work effectively, termination impedances for passband and stopband are very important.
Show me output reflection coefficient of transmitter by network analyzer measurement.
Show me S-parameters(S11,S12,S21,S22) of one LPF and cascaded two LPF.
What do you mean by "ann" ?
Don't use unfamiliar abbreviation.
Try to insert lossy matching pad between transmitter and LPF or between two LPFs.
http://www.rfcafe.com/references/electrical/attenuators.htm
aaron_do
Reply #4 - May 21st, 2010, 8:41am
Quote:
Wave..
As far as I know the 1st harmonic is the fundamental. Regardless, you obviously need some humility to go along with your expert advice.
rfcooltools.com
Reply #5 - May 21st, 2010, 10:35am
Are you sure that your transmitter is getting distortion from the spec analyzer, try setting the attenuation in the spec analyzer 10dB more and if your 866MHz spur drops more than 10dB then that is a contributor.  Also goto http://www.rfcooltools.com and experiment with the filter synthesis tool.
