Jul 20th, 2024, 3:17pm
Designing an output stage! (Read 2571 times)
samiran
May 20th, 2010, 6:06am
Dear All,
I need to design an output stage (third stage) for a two-stage compensated opamp. I have gone through some related papers and text. After reading them, I have built-up some interpretations:
1. The main design specifications whilst designing the o/p stage are a) output swing, b) power dissipation (or efficiency), c) linearity (or THD). Please let me know are there anything else I need to consider.
2. My 2stage diff-amp works with 1.8 V - 0 V supply rail. So, the output stage also need to be designed among those. Which topology should I go for?
3. After inserting the third stage is it required to again compensate the whole circuit? And any other design metric dependent upon both the driver stage and output stage needs to be considered?
4. Any simple design guideline is very much appreciated.
Please help me.
Thanks & regards
Samiran
Mayank
Re: Designing an output stage!
Reply #1 - May 20th, 2010, 7:20pm
Yes, The kind of load it needs to drive & how much of it ?
Depends on the above mentioned factors + the answer.
Yes, Esp. if the output driver's a gain stage.
Again there are numerous topologies ranging from a simple common drain config to complex drivers like class AB & others. Choose the one which fits your specs. There's plenty of material on output stages.
Mayank
love_analog
Reply #2 - May 31st, 2010, 7:48am
You need to tells us what kind of load and gain you desire.
Typically you put a 3rd stage if you have to drive a low resistance and prevent that from loading the 2 stage opamp.
loveanalog.blogspot.com
The Power of Analog
ampbuilder
Reply #3 - Jun 22nd, 2010, 2:29pm
Can try Common Emitter/Source; it alone can swing to +/-sat voltage off the rail which is about 0.2V for a BJT but watch out, gain depends on load.
