Minnie,
AMS Designer is the Cadence simulator for mixed-signal simulation, simulating with Verilog-AMS. AMS Designer is included in the digital simulator release stream, IUS. So you will need to include IUS in your path.
To use AMS Designer, you need to select the simulator in ADE, Setup --> Simulator/Directory/Host --> ams. You will need to setup to run the simulation correctly, you may wish to contact your local support for help.
In addition, to the models on the Designer's Guide, there are some useful models contained in bmslib in the samples directory.
