Jul 18th, 2024, 12:30pm
HELP! verilog-ams simulation (Read 2717 times)
minnie
May 26th, 2010, 12:02am
hello, i have a simple problem with pll simulation with verilog-ams.
i'd like to use ic5141 to simulate,please tell me wether it works, for i used to see some people said i need to a tool named "ius".
what else , i download the model of pll of the website, there are a few files in it , with different file stye. How can i use it in ic5141?
thx very much
                                  minnie
Re: HELP! verilog-ams simulation
Reply #1 - May 26th, 2010, 5:19am
Minnie,
  AMS Designer is the Cadence simulator for mixed-signal simulation,
simulating with Verilog-AMS. AMS Designer is included in the digital
simulator release stream, IUS. So you will need to include IUS in
your path.
   To use AMS Designer, you need to select the simulator in ADE,
Setup --> Simulator/Directory/Host --> ams. You will need to setup
to run the simulation correctly, you may wish to contact your local
support for help.
  In addition, to the models on the Designer's Guide, there are some
useful models contained in bmslib in the samples directory.
