zhangjerome
The problem is that I can only save the voltage of top-level and 2nd level nets. When I want to select and save some 3nd or 4th level nets voltage, a warning message says "no valid full path name for net XXX". The LVS is sucessful and shows the layout and schematic matches.
I use Cadence Hierarchy editor to do the parasitic simulation.
Thank you.
