Jul 16th, 2024, 6:35pm
Questions about Assura flow of parasitic simulation (Read 1577 times)
zhangjerome
May 31st, 2010, 8:23pm
The problem is that I can only save the voltage of top-level and 2nd level nets. When I want to select and save some 3nd or 4th level nets  voltage, a warning message says "no valid full path name for net XXX".  The LVS is sucessful and shows the layout and schematic matches.
I use Cadence Hierarchy editor to do the parasitic simulation.
Thank you.
