Jul 16th, 2024, 6:43pm
Mismatch Parameters don't change in MonteCarlo of Cadence Spectre (Read 3525 times)
Jun 1st, 2010, 4:55am
The following is extractions of model file for MonteCarlo simulation from Cadence Generic PDK(gpdk180_v3.3.tar.gz).
When I run simple DC monte carlo analysis using this model file with only "mismatch" variations,
only two parameters out of nine parameters are active, but other seven parameters don't change at all.
Here active parameters are only "xl" and "vth0".
"tox", "xw", "cj", "cjsw", "cjswg", "cgdo", "cgso" and "hdif" don't change at all.
Why do other parameters not change during MonteCarlo Analysis of Cadence Spectre ?
Quote:
*   Generic PDK BSIM3V3 Spectre nmos1.scs           02/02/06
*   NMOS                                          PDK Factory
* 05/04/19 - R. Mullen changed capmod from 0 to 2
* 05/04/19 - R. Mullen add stat models
* 05/10/15 - J. McMahon - Added more representive 180nm noise model parameters
simulator lang=spectre
library gpdk
* Statistical
section stat
* Process parameters
parameters toxn=4.0e-9  toxn_std=0.2e-9
parameters dvthn=0      dvthn_std=0.04
parameters dlxn=0       dlxn_std=2e-9
parameters dxwn=0       dxwn_std=2e-9
parameters cjn=0.0010   cjn_std=0.00015
parameters cjswn=2.0e-10  cjswn_std=0.3e-10
parameters cjswgn=3.3e-10 cjswgn_std=0.5e-10
parameters cgon=3.7e-10   cgon_std=0.6e-10
parameters hdifn=2e-7     hdifn_std=2e-8
* Mismatch parameters
parameters mtoxn_std=0.02e-9
parameters mdvthn_std=0.004
parameters mdlxn_std=0.2e-9
parameters mdxwn_std=0.2e-9
parameters mcjn_std=0.000015
parameters mcjswn_std=0.03e-10
parameters mcjswgn_std=0.05e-10
parameters mcgon_std=0.06e-10
parameters mhdifn_std=0.2e-8
statistics {
//        process {
//                vary toxn  dist=gauss std=toxn_std
//                vary dvthn dist=gauss std=dvthn_std
//                vary dlxn  dist=gauss std=dlxn_std
//               vary dxwn  dist=gauss std=dxwn_std
//                vary cjn   dist=gauss std=cjn_std
//                vary cjswn dist=gauss std=cjswn_std
//                vary cjswgn dist=gauss std=cjswgn_std
//                vary cgon  dist=gauss std=cgon_std
//                vary hdifn dist=gauss std=hdifn_std
       mismatch {
               vary toxn  dist=gauss std=mtoxn_std
               vary dvthn dist=gauss std=mdvthn_std
               vary dlxn  dist=gauss std=mdlxn_std
               vary dxwn  dist=gauss std=mdxwn_std
               vary cjn   dist=gauss std=mcjn_std
               vary cjswn dist=gauss std=mcjswn_std
               vary cjswgn dist=gauss std=mcjswgn_std
               vary cgon  dist=gauss std=mcgon_std
               vary hdifn dist=gauss std=mhdifn_std
include "nmos1.scs" section=mos
endsection stat
section mos
inline subckt nmos1(D G S B)
   parameters w=1u l=1u as=1u ad=1u ps=1u pd=1u region=1
model nmos1_int bsim3v3  {
* 1: *   .18u <= gate length <= .5u   &&    .4u <= gate width < 10u
* 2: *   .5u  <  gate length <= 1.0u  &&    .4u <= gate width < 10u
* 3: *   1.0u <  gate length <= 20u   &&    .4u <= gate width < 10u
* 4: *   .18u <= gate length <= .5u   &&    10u <= gate width < 100u
* 5: *   .5u  <  gate length <= 1.0u  &&    10u <= gate width < 100u
* 6: *   1.0u <  gate length <= 20u   &&    10u <= gate width < 100u
1: type=n lmin=0.18e-6  lmax=0.501e-6   wmin=0.4e-6  wmax=10.001e-6
+ minr=1e-60 tnom=25 version=3.1 tox=toxn xj=1.6e-7 nch=3.9e+17
+ lln=1 lwn=1 wln=1 wwn=1 lint=1e-8 ll=0 lw=0 lwl=0 wint=1e-8 wl=0 ww=0 wwl=0
+ mobmod=1 binunit=2 xl=-2e-8 + dlxn xw=0 + dxwn dwg=0 dwb=0 ldif=9e-8
+ hdif=hdifn rsh=6.8 rd=0 rs=0 vth0=0.48 + dvthn lvth0=1.18e-8 wvth0=-7.08e-9
+ puc1=3.17e-23 kt1l=0 prt=0 cj=cjn pb=0.69 mj=0.36 cjsw=cjswn pbsw=0.69
+ mjsw=0.20 cjswg=cjswgn pbswg=0.69 mjswg=0.44 cgdo=cgon cgso=cgon
+ noimod=2 noia=5.0e+19 noib=4.0e3 noic=-4.0e-13 em=3.0e+07 ef=0.883
6: type=n lmin=1.0e-6   lmax=20.001e-6  wmin=10e-6   wmax=100.001e-6
+ tnom=25 version=3.1 tox=toxn xj=1.6e-07 nch=3.9e+17
+ lln=1 lwn=1 wln=1 wwn=1 lint=1e-08 ll=0 lw=0 lwl=0 wint=1e-08 wl=0 ww=0 wwl=0
+ mobmod=1 binunit=2 xl=-2e-08 + dlxn xw=0 + dxwn dwg=0 dwb=0 ldif=9e-08
+ hdif=hdifn rsh=6.8 rd=0 rs=0 vth0=0.45 + dvthn lvth0=4.08e-08 wvth0=-1.48e-07
+ puc1=-1.05e-21 kt1l=0 prt=0 cj=cjn pb=0.68 mj=0.36 cjsw=cjswn pbsw=0.68
+ mjsw=0.2 cjswg=cjswgn pbswg=0.69 mjswg=0.49 cgdo=cgon cgso=cgon
   nmos1 (D G S B) nmos1_int w=w l=l as=as ad=ad ps=ps pd=pd region=region
ends nmos1
endsection mos
endlibrary gpdk
« Last Edit: Jun 01st, 2010, 7:09am by pancho_hideboo »
Re: Mismatch Parameters don't change in MonteCarlo of Cadence Spectre
Reply #1 - Jun 4th, 2010, 9:42am
Self follow up.
I can make all nine mismatch parameters change correctly by modifying model file like following.
This modified model file is effective for Cadence Spectre, Agilent RFDE(ADSsim) and Agilent GoldenGate.
*   NMOS                                          PDK Factory
library gpdk
* Statistical
section stat
parameters dxln=0       dxln_std=2e-9
parameters mdxln_std=0.2e-9
statistics {
//        process {
//                vary dxln  dist=gauss std=dxln_std
       mismatch {
               vary dxln  dist=gauss std=mdxln_std
endsection stat
section mos
+              tox=toxn dvth=dvthn dxl=dxln dxw=dxwn
+              cj=cjn cjsw=cjswn cjswg=cjswgn cgo=cgon hdif=hdifn
+ minr=1e-60 tnom=25 version=3.1 tox=tox xj=1.6e-7 nch=3.9e+17
+ mobmod=1 binunit=2 xl=-2e-8 + dxl xw=0 + dxw dwg=0 dwb=0 ldif=9e-8
+ hdif=hdif rsh=6.8 rd=0 rs=0 vth0=0.48 + dvth lvth0=1.18e-8 wvth0=-7.08e-9
+ puc1=3.17e-23 kt1l=0 prt=0 cj=cj pb=0.69 mj=0.36 cjsw=cjsw pbsw=0.69
+ mjsw=0.20 cjswg=cjswg pbswg=0.69 mjswg=0.44 cgdo=cgo cgso=cgo
+ cta=0.001 ctp=0.0006 pta=0.0016 ptp=0.0016 js=8.38e-6 jsw=1.6e-11
+ n=1 xti=3 capmod=2 nqsmod=0 xpart=1 cf=0 tlev=1 tlevc=1 dlc=3e-9
+ tnom=25 version=3.1 tox=tox xj=1.6e-07 nch=3.9e+17
+ mobmod=1 binunit=2 xl=-2e-08 + dxl xw=0 + dxw dwg=0 dwb=0 ldif=9e-08
+ hdif=hdif rsh=6.8 rd=0 rs=0 vth0=0.45 + dvth lvth0=4.08e-08 wvth0=-1.48e-07
+ puc1=-1.05e-21 kt1l=0 prt=0 cj=cj pb=0.68 mj=0.36 cjsw=cjsw pbsw=0.68
+ mjsw=0.2 cjswg=cjswg pbswg=0.69 mjswg=0.49 cgdo=cgo cgso=cgo
+ cta=0.001 ctp=0.0006 pta=0.0015 ptp=0.0015 js=8.38e-06 jsw=1.6e-11
ends nmos1
endsection mos
endlibrary gpdk
