Sep 28th, 2024, 3:07pm
Running parametric sims using Ocean (Read 2057 times)
gsradhak
Jun 02nd, 2010, 1:06pm
I have a set of design variables in my schematic. I would like to input multiple data vectors to my schematic and save the output data in Ocean
For example, If P is a set of parameters P={p1,p2,p3,p4} (p1-p4 are the design variables in the schematic). I would create a matrix of data values with different instances of P ie my data matrix would look like
Q=[-------P1---------
    --------P2---------
   ---------P3--------]
and so on where each Pi contain (p1i, p2i,p3i,p4i). (In other words I want to use the analogus of paramset command in Spectre for ocean). I would like to simulate my circuit for these values in Q and make some measurements using Calculator function and finally store the output data in the text file. Can somebody please go through the steps in accomplishing the same?
Guru
Re: Running parametric sims using Ocean
Reply #1 - Jun 25th, 2010, 10:53pm
--- Method-1 Quote:
declare( p1[3] )
declare( p2[3] )
declare( p3[3] )
declare( p4[3] )
; Design Parameter's Values for P1 sets
p1[0] = 1
p2[0] = 2
p3[0] = 3
p4[0] = 4
; Design Parameter's Values for P2 sets
p1[1] = 10
p2[1] = 20
p3[1] = 30
p4[1] = 40
; Design Parameter's Values for P3 sets
p1[2] = 100
p2[2] = 200
p3[2] = 300
p4[2] = 400
base_dir = "xxxxx"
for( i, 0, 2
  desVar( "p1", p1[i] )
  desVar( "p2", p2[i] )
  desVar( "p3", p3[i] )
  desVar( "p4", p4[i] )
  resultsDir( sprintf(nil, "%s/P%d", base_dir, i+1) )
  run()
--- Method-2 Quote:
; Design Parameter's Values for Q sets
p1_list = list(1, 10, 100)
p2_list = list(2, 20, 200)
p3_list = list(3, 30, 300)
p4_list = list(4, 40, 400)
base_dir = "xxxxx"
n = length(p1_list)
for( i, 0, n-1
 desVar( "p1", nth(i, p1_list) )
 desVar( "p2", nth(i, p2_list) )
 desVar( "p3", nth(i, p3_list) )
 desVar( "p4", nth(i, p4_list) )
 run()
--- Method-3 Quote:
Q = list(
         (  1,   2,   3,   4),    ; Design Parameter's Values for P1 sets
         ( 10,  20,  30,  40),    ; Design Parameter's Values for P2 sets
         (100, 200, 300, 400)     ; Design Parameter's Values for P3 sets
base_dir = "xxxxx"
i = 0
foreach( Pi, Q
  ++i
  desVar( "p1", nth(0, Pi) )
  desVar( "p2", nth(1, Pi) )
  desVar( "p3", nth(2, Pi) )
  desVar( "p4", nth(3, Pi) )
  resultsDir( sprintf(nil, "%s/P%d", base_dir, i) )
  run()
« Last Edit: Jun 26th, 2010, 4:04am by pancho_hideboo »
