Oct 2nd, 2026, 10:52am
current-mode passive mixer problem (Read 9999 times)
kibby
Jun 07th, 2010, 12:04am
   I am designing a current-mode passive mixer which consists of gm,mixer core and tia stages. The mixer core is ac coupled to the first stage. I wonder about the input offset voltage of tia, is it feedback by the resistor or other ways?
   I tried to use the feedback resister. The input and output common mode voltage is vcc/2 at most times. By as I tried to enlarge the ratio of input and load mosfets to mitigate flicker noise. The cm voltage becames vcc. The input mosfets are pmos. Does it means that a start-up circuit is needed?
   Thank you for your help Smiley
Mayank
Re: current-mode passive mixer problem
Reply #1 - Jun 7th, 2010, 11:24pm
Yes, generally it's a feedback by a resistor..Unless you wanna plunge into complexity of SC circuits.
Seems like a Loop Stability Problem to me.
Your loop(check both CM loop & DM loop) might be going unstable because of the excess gain introduced by increasing MOS W/Ls & because of Shifted Poles due to larger parasitics from increased sizes.
Mayank
kibby
Reply #2 - Jun 8th, 2010, 4:54am
   Thank you, Mayank~
   The PM of both DM(open loop) and CM loop are 90° and 60°, I think it`s enough. But the problem still exists. I don`t know how does spectre do dc analysis, but I don`t think the problem relates to ac response.
   Since there is no dc voltage or current after mixer core. If the input node of tia begins with a random voltage like vcc. Then it seems that the whole circuit can`t work. Why not just bias the input node (vcc/2) of tia with a large resistante?
rfcooltools.com
Reply #3 - Jun 8th, 2010, 2:53pm
Sounds like your circuit has a common loop has more than one solution, the desired and either a transient or permanent trap state when the input and output cmode is vcc, if its a transient in nature you may not be seeing it resolve itself due to  the length of your simulation time.  I would suggest finding the root cause because these issues are usually a clue to other potential problems.  A lot of times this can be solved by making the cmode current transistor to provide a maximum of 50% of the total bias current. If you are short on time  take your own suggestion and bias it to vcc/2.
http://rfcooltools.com
aaron_do
Reply #4 - Jun 9th, 2010, 8:36pm
I think you were right in that your circuit is not starting up. If you show us your schematic it would help but I can understand if you don't want to. You can ensure start-up by either adding some start-up transistors, or by making sure your common-mode feedback loop allows the circuit to start-up.
Out of curiousity, why did you AC couple the mixer core to the op-amp? Are you trying to get a high-pass function? If so, the corner frequency of your HPF depends on the average resistance of the mixer core (for a double balanced mixer core). The smaller the on-resistance, the larger the capacitors you need.
Also, if your mixer core is a double-balanced type (as is normal), you should look out for your TIA loop gain which will depend on the average resistance of the mixer core. Your loop gain will affect the TIA linearity.
cheers,
Aaron
kibby
Reply #5 - Jun 11th, 2010, 4:58am
Thank you Aaron!
//Out of curiousity, why did you AC couple the mixer core to the op-amp?
May be you misunderstand my meaning. Here is the system and block schematic.
Now I want to bias the input node of tia with a large resitance(bias at vcc/2) so that the start-up problem can be solved. As far as I know, the large resistance will not add additional noise, maybe a little input offset voltage. But if I  use a  start-up circuit, it will also add noise and additional complexity. Could you give some suggestions?
Thank you for your help~
kibby
Mayank
Reply #6 - Jun 11th, 2010, 5:17am
AC Couple the Mixer's Output to the input of TIA through a decoupling cap.
DC Bias the input at TIA by dropping mixer o/p current into a resistor to VDD/GND.
This is what is done generally. Rest of your circuit looks fine to me.
rfcooltools.com
Reply #7 - Jun 11th, 2010, 11:15am
if IFin is high Node A can be undefined so you will need to define A by putting two current sources one in parallel with M3 and one in parallel with M4 which are always on.  This will solve your start up issue.
kibby
Reply #8 - Jun 11th, 2010, 7:23pm
Happy to see you Mayank~ The receiver is designed to directly down-convert the rf signal. As the IF frequency is zero, the mixer core cannot ac couple to tia or the cap may be too large.
Thank you rfcooltools.com, the suggestions are good. However, when I use the tool initial condition in spectre simulation to do transient simulation, I find that the ota with resistance feedback can start if the initial voltage at input node is 0 to near vcc. Though the dc simulation remains wrong...
RFICDUDE
Reply #9 - Jun 12th, 2010, 5:32am
Do you have a circuit on the input of the TIA (or at the input to the mixer) to set the CM voltage at the input of the TIA to be the same as the output CM voltage?
The CM voltage can be connected to the TIA or mixer input with large resistors since you are just trying to establish the DC CM voltage.
All this will do is to allow the input CM to be the same as the output CM such that the output doesn't need to supply any current through the feedback resistor to establish a stable input CM level.
The circuit may not be necessary, but perhaps it is related to your issue?
kibby
Reply #10 - Jun 12th, 2010, 6:12pm
Thank you RFICDUDE!
The CM of input of TIA should be feedback by the resistance so it is the same as output CM voltage.I use a large resistance to bias the input of TIA just to avoid start-up problem.
kibby
RFICDUDE
Reply #11 - Jun 13th, 2010, 3:35am
Well then you should take rfcooltools advice and see if the CM of the OTA is stuck in a metastable state.
If node "IF" starts out at Vdd then the CMFB circuit should make Vfb fairly high. If Vfb is high and "IF" at Vdd and the volt"A" is low then the OTA is stuck because the input PMOS pair is off.
I think, normally, there would be some leakage currents that would help charge node A up, but maybe not since the NMOS loads are sinking any leakage currents that maybe present.
You might try what rfcooltools suggested (a circuit to pull node A up) or lower your CM reference voltage such that the input PMOS pair and current source will be in saturation.
You should analyze the input CM range of the diffpair and current source and then determine if changes need to be made to align the input and output CM requirements.
Analog design is 10% inspiration and 90% bias robustness.
aaron_do
Reply #12 - Jun 13th, 2010, 4:53am
Hi Kibby,
looks like you already have plenty of good suggestions. Anyway from your schematic there is clearly a start-up issue. I think a good option would simply be to add a couple of transistors in the right places to start-up the op-amp. They can safely turn off when the op-amp is on and may not affect the operation much. Alternatively, you could change your CMFB arrangement so that the op-amp is able to start up.
If you add biasing resistors, you may run into a couple of problems. The biasing resistors would have to be small enough to ensure the op-amp is able to start, and large enough not to add noise to the circuit. If you can live with the small capacitance they add, start-up transistors are a better idea IMO.
BTW that is an interesting arrangement you have. I guess your loop gain is now affected by the transconductor's output impedance. Looks like the loop gain will be difficult to calculate...
cheers,
Aaron
