Jul 20th, 2024, 5:27pm
Pages: 1 2
Stable Iref across PVT (Read 11100 times)
newic
Jun 09th, 2010, 2:33am
Want to generate a stable across PVT Iref to opamp and other circuits.
What are the alternative?
Bandgap reference Vref?
However, it is still sensitive to Vdd unless voltage regulator is used, right?
The generated Vref from bandgap is stable across temperature (Vref variation=+/-0.5%). However, when converting vref to current Iref, the Iref becomes sensitive to temperature due to Vt variation, resulting in about +/-5% Iref variation or total 10%.
Any guidance?
XY-oriented
Re: Stable Iref across PVT
Reply #1 - Jun 9th, 2010, 2:39am
I would say +/-5% is pretty decent ... your design should be robust enough to stand 10% bias current variation.
any circuit that canī t stand +/-10% bias variation is a bad one in my opinion.
newic
Reply #2 - Jun 9th, 2010, 2:42am
that is just the temperature variation.
it does not account for the process and voltage variations.
XY-oriented
Reply #3 - Jun 9th, 2010, 3:02am
then you should think of trimming your bandgap so to limit process variation to +/-5%
AnalogDE
Reply #4 - Jun 9th, 2010, 9:16am
Just curious, how are you doing a BGVref to Iref conversion?
Mayank
Reply #5 - Jun 9th, 2010, 9:27pm
For Temp,
  Instead of making a BGap Voltage Reference, generate a Zero Temp. Coefficient Current from BandGap Core.
For Process,
  Trim BG resistors to get desired current value.
For Voltage,
   Keep PSR of the Loop High Enough. V variation should not be a problem then.
Result : - You get A Current Ref. independent of PVT variation.
Mayank.
newic
Reply #6 - Jun 9th, 2010, 11:56pm
Hi Mayank,
it makes sense to make deriv_Iref/deriv_temp = 0 instead of deriv_Vref/deriv_temp = 0.
what if I need both Vref & Iref independent PVT?
Mayank
Reply #7 - Jun 10th, 2010, 1:11am
Quote:
Hi Mayank,
Use Different Circuits. That's the Common practice
newic
Reply #8 - Jun 10th, 2010, 9:59pm
Use BG Vref to convert to Iref.
Is it a common practice?
newic
Reply #9 - Jun 10th, 2010, 11:53pm
how to trim the resistor?
adding a fuse? (resistor that parallel with a transistor)
Mayank
Reply #10 - Jun 11th, 2010, 12:02am
Be advised.
If you want to use BG_VREF to create I_REF, it is difficult to get exact temperature compensation, leave alone process. For BG_VREF / Res technique, you require Res. trimming to eliminate process variation.
Better Sol. --
Build a BG_VREF BandGap Circuit with Zero Temperature Coefficient Voltage.               (Generally, PTAT current * CTAT resistance = ZTC voltage)
Build another IREF BandGap Circuit with Zero Temp. Coeff. CURRENT, not ZTC voltage. (Generally, CTAT current +PTAT current= ZTC current )
Then apply trimming after fab to get precise PVT compensated VREF & IREF.
Mayank
newic
Reply #11 - Jun 11th, 2010, 12:13am
Thank you very much!
Smiley
newic
Reply #12 - Jun 15th, 2010, 10:16pm
What is the normal current value in the bandgap core and Iref?
Normally the core current is very small <50uA. I read from papers,  is it true? will it suspectible to interference?
How about Iref value as a global current distribution.
Mayank
Reply #13 - Jun 16th, 2010, 2:41am
Inside BGR core -- < 50uA
Inside Current References core -- < 100uA
Current being small is true. Layout of these blocks is done with extreme care which takes care of averting susceptibility to substrate noise, etc.
As raja quoted somewhere, dont keep current multiplication ratios bigger than 100x. It increases the noise in the current.
mayank.
RobG
Bozeman, MT
Reply #14 - Jun 16th, 2010, 2:12pm
Mayank wrote on Jun 11th, 2010, 12:02am:
Be advised.
Better Sol. --
Mayank
FWIW, you can do it with just a voltage source and a ZTC resistor. if you don't have a ZTC Resistor available you can create one by using two resistances of opposite temp co. You also get less process variation using two resistances, assuming they are statistically independent. For giggles I wrote up a paper on how to do it and maintain the same temp co even if the two sheet resistances change in opposite directions. http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.76.2458&rep=rep1&type=p...
But like you say, the big issue is the variation in sheet resistance, which you will need to trim out or use an external resistor.
Pages: 1 2
