Jul 20th, 2024, 7:29pm
Pages: 1 2
Stable Iref across PVT (Read 11108 times)
Mayank
Re: Stable Iref across PVT
Reply #15 - Jun 16th, 2010, 9:04pm
Agree with RobG here.
But in VBG / Rztc, it's difficult to obtain compensated umbrella across Process Corners.
In BGR Core ZTC Iref Generation, the umbrella shape is more or less preserved across Process Corners.
newic
Reply #16 - Jun 19th, 2010, 8:47pm
it is nice to cancel out the positive TC (PTC) resistor with negative TC (NTC) resistor to get independent temperature.
However, the process variation of these two resistors might be different. Unless both the PTC & NTC resistors are the same type (poly type) BUT poly resistors are PTC type.
newic
Reply #17 - Jun 19th, 2010, 8:54pm
Quote:
Inside BGR core -- < 50uA
Inside Current References core -- < 100uA
Could you explain these BGR core & Current references core.
I think i might be confused.
It is great if the pictures or papers are shown.
Mayank
Reply #18 - Jun 20th, 2010, 10:53am
Typical BGR core consists of a normal ΔVBE + VT*ln(n) compensation.
or in other words, VBE1 = VBE2 + Iptat*R.
Typical Current Reference Core, includes extra Resistance arms connected in parallel with the branches of a BGR core to provide CTAT current, which then adds up with PTAT current generated by the BGR core, thus providing ZTC current.
Pls. Refer Voltage References by Gabriel Rincon Moora.
--M
RobG
Bozeman, MT
Reply #19 - Jun 20th, 2010, 9:26pm
newic wrote on Jun 19th, 2010, 8:47pm:
Actually not necessarily true about the process variation... read the paper I referenced. It shows how to make composite resistors so that the independent sheet resistance variations do not affect the overall temp co of the composite resistance.
rg
[edited to clarify]
« Last Edit: Jun 21st, 2010, 9:00am by RobG »
Pages: 1 2
