Sep 26th, 2026, 12:51pm
Unexpected value of noise (Read 4402 times)
Vladislav D
The Netherlands
Jun 10th, 2010, 12:16pm
We all know that the output noise of two resistor is 4*k*T*(R1 || R2). So, if both resistors have value of 50 Ohms, the output noise is 0.644nV/sqrt(Hz) (T=300K). If I simulate the circuit with two resistors and a voltage source I get the same result, however, if I substitute series resistor and voltage source with 50-Ohms port the output noise becomes 638nV/sqrt(Hz). I cannot find the explanation of this effect. Is this bug or I missed something?
« Last Edit: Jun 10th, 2010, 1:23pm by Vladislav D »
rfcooltools.com
Re: Unexpected value of noise
Reply #1 - Jun 10th, 2010, 8:56pm
In Cadence the port has its own temperature.  you may want to check what the default is set to.
http://rfcooltools.com
Reply #2 - Jun 12th, 2010, 6:52am
I can't find out any design isuue in your question.
Your question is no more than very easy issue of very specific vendor's simulator.
What simulator do you use ?
Vladislav D wrote on Jun 10th, 2010, 12:16pm:
Vout2=4*k*{R2/(R1+R2)}2*(R1*T1+R2*T2)
Here R1 and T1 mean resistance and temperature of "port" respectively.
If R1=R2=50, Vout2=50*k*(T1+T2)
If T1=T2=300K, Vout=643.6[pVrms/sqrt(Hz)].
If T1=290K, T2=300K, Vout=638.2[pVrms/sqrt(Hz)].
See http://www.designers-guide.org/Forum/YaBB.pl?num=1192525133/10#10
The followings are general notes for you.
- Always describe correct tool's name and vendor's name which you use as tool or simulator.
- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
« Last Edit: Jun 12th, 2010, 7:58am by pancho_hideboo »
Reply #3 - Jun 14th, 2010, 5:07am
Agilent ADSsim treat temperature of port as analysis temperature, if it is not specified for all analyses except for SP-Analysis.
In SP-Analysis of Agilent ADSsim, ADSsim treats port temperature as 290[K] even if you set any value as port temperature.
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1192525133/10#10
