Jul 17th, 2024, 11:33pm
Cap size for pipelined ADC (matching question) (Read 5528 times)
carlgrace
Berkeley, CA
Jun 15th, 2010, 9:47am
I'm a bit confused about choosing caps based on mismatch data.  Say, for instance, that the process I'm using claims I need 1.2 pF of capacitance for a three-sigma mismatch of 0.1% (I'm trying to build a 10-bit ADC).  Now, does that mean both the sampling and feedback cap need to be 1.2 pF to get this matching, or is the total capacitance I'm sampling with (two caps) need to be 1.2 pF so each cap can be 600 fF?  The design manual is not clear about this.
Carl
RobG
Bozeman, MT
Re: Cap size for pipelined ADC (matching question)
Reply #1 - Jun 16th, 2010, 5:27pm
Who knows... Generally the number is between two caps of equal size, so you would need both caps to be 1.2pF. However, I'd check with the guys who gave you the number!
Mayank
Reply #2 - Jun 16th, 2010, 9:57pm
Both need to be 1.2pF individually. That's how i would interpret it.
--M
Maks
San Jose
Reply #3 - Jun 18th, 2010, 7:23am
carlgrace wrote on Jun 15th, 2010, 9:47am:
Carl
And don't forget about the mismatch induced by the layout and capacitive coupling to the nets surrounding the unit caps.
vivkr
Reply #4 - Jun 22nd, 2010, 1:56am
Read the process manual carefully. Usually, they specify how the mismatch is defined and sometimes even the test structure used. Note that the definition may not be consistent with the setup used.
Nonetheless, it says somewhere whether the variation is computed for mismatch between 2 identical caps of size C or if it would be the variation of 1 cap with respect to its mean value.
Vivek
Reply #5 - Jun 27th, 2010, 10:42am
Don't forget the KT/C calculation as well. 10 bits?
I would get 3-6dB noise margin on just that.
That might dictate a larger set of capacitors, you need to
go do the math and put margin into the design.
carlgrace
Berkeley, CA
Reply #6 - Jun 27th, 2010, 3:31pm
I did do the kT/C noise calculation and I'm mismatch limited at 10 bits for my signal swing.  Getting answers out of TSMC is like getting blood out of a stone.  I'm sure they have a document with detailed mismatch data.  Why they won't send it to me and seem to be deliberately misunderstanding my questions is beyond me.  I'm going to do a couple simple simulations with the statistical models and see if they correlate with what I expect.  Thanks for the help, everyone!
Carl
