Aug 16th, 2024, 7:51pm
CML Ringoscillator (Read 457 times)
znieH
CML Ringoscillator
Jun 17th, 2010, 2:57am
my first project in Circuit Designing is a CML Ringoscillator, that consists of 53 Inverter. The Inverters are designed as differential pair of SiGe HBTs. I perform PreLayout as well as PostLayout (transmission lines included) simulations in Spectre.
Shocked What is strange for me, is that the output frequency of the PostLayout simulation with parasitics is faster (about 20%). I think that is because there is an additional inductance in series to the collector resistance (Rc) through adding the transmission lines, but I can not really explain for myself why. Can anybody help me?
Regards and thanks in advance.
rfcooltools.com
Re: CML Ringoscillator
Reply #1 - Jun 17th, 2010, 4:35pm
Time const is set by R || Ccb and in parallel with (Cbe+Ce of the next device ). So it may be that the impedance at the emitter has increased possibly because of resistance to the current source.
http://rfcooltools.com
Mayank
Reply #2 - Jun 17th, 2010, 9:10pm
Please Check your models.
20% faster is a huge difference in simulation b/w layout & schematic simulation.
Generally, post-layout is slower due to added routing capacitances.
I dont think interconnect inductance would be huge enough to cause a visible effect.
An increase in Impedance would increase the Time Constant, thereby decreasing frequency.
rfcooltools.com
Reply #3 - Jun 17th, 2010, 10:31pm
Mayank,
What do you think the time const will increase or decrease?
Mayank
Reply #4 - Jun 17th, 2010, 11:27pm
Below is the attached figure as i understand....
znieH
Reply #5 - Jun 18th, 2010, 12:41am
First of all thanks for your andwers.
@Mayank
Please Check your models. 20% faster is a huge difference in simulation b/w layout & schematic simulation. Generally, post-layout is slower due to added routing capacitances.
It is a new process, designers told me automatic post layout simulation is not yet  possible. Parasitics have to be included by hand, so there is at the moment only the model of the transmission lines in series with its resistance, no routing capacitances included.
I added in the Pre-Layout a inductance in series to Rc and the output frequency increase as in the Post-Layout simulation. Designers told me its a shock inductance but I asked google and found nothing that explain my problem. (Only for understanding the designers are french and their english is not so good, so I have to find out by myself.)
znieH
Reply #6 - Jun 18th, 2010, 12:47am
Could it be that the matching between the inverter stages is improved by the inductor in series to Rc??
Hope I didn't say something stupid Roll Eyes
Mayank
Reply #7 - Jun 18th, 2010, 3:16am
Which transmission lines are you talking about ?
Are you including any such T-line models in your schematic ??
Havent heard of any shock inductance arising at source node, unless you deliberately place one.
znieH
Reply #8 - Jun 18th, 2010, 3:53am
Yes, it is only the vias that had to be calculated by hand.
I think I found what they have meant. The effect is called SHUNT PEAKING. And sorry if I was not precise enough, but I was talking of HBTs and  the inductance is between the node of the collector and the Rc resistance.
rfcooltools.com
Reply #9 - Jun 18th, 2010, 9:31am
Mayank,
TC=2*pi/(RC)
You have it inverted in your diagram.
Mayank
Reply #10 - Jun 20th, 2010, 10:47am
Last Time i checked, Time Constant is RC or L/R.
F-3db = 1/(2*pi*TC) though if that's what you are referring to.
