Sep 19th, 2026, 8:33pm
`wrealStateZ and wreal ports in verilog ams (Read 4111 times)
E van der Heijden
Jun 17th, 2010, 2:09am
I am trying to get to grips with wreal modelling in verilog ams, so please forgive any 'stupid' questions.
I am trying to substitute verilog ams blocks into a top level schematic, using Cadence's Hierarchy Editor and ADE simulation environment. I have a very simple model of a transmission gate, which I've coded as follows:
//Verilog-AMS HDL for "adcLib", "tx_gate" "verilogams"
`include "constants.vams"
`include "disciplines.vams"
module tx_gate ( out, enable, in, not_enable );
 input wreal in;
 input enable;
 input not_enable;
 output wreal out;
 real out_wire ;
 always@(enable or not_enable)
   begin
     if (enable)
           out_wire = in;
     else
           out_wire = `wrealZState;
 assign out = out_wire;
but it doesn't work, there is no output in either state.
What have I done wrong?
Are the port declarations and useage correct?
can I use `wrealstateZ like this?
Any enlightment would be appreciated!
Thank you,
E
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: `wrealStateZ and wreal ports in verilog ams
Reply #1 - Jun 25th, 2010, 7:10am
Hi E,
If you try to print the values using $display you will see what happens: the `wrealZState value is translated to nan if nothing else is attached to the out terminal.
Cheers,
Marq
