Jul 17th, 2024, 10:40am
adc verilogA errors! (Read 7853 times)
supermoment
Jun 25th, 2010, 1:18am
The code was copied from designers-guide.org. So it should be correct.
I got several errors about the code and i do not know how to solve it.
I am using IC5141, mmsim61.
The errors i got:
Line 36
"for(i = bits-1; i >= 0; i = i-1 )<<--?  begin"
Line 36
Error: In for-loop control, genvar expression can only consists of
       integer constant or other unrolled genvar variables expression.
Line38
       "result[i]<<--?  = vdd;"
       Error: Genvar variable `i' is referenced within incorrect for-loop.
Line41
       "result[i]<<--?  = 0.0;"
many more
Sound like those errors occurs whenever i use [i] or i
Is it my verilogA compiler too old? I am not sure how to check the version.
`include "constants.vams"
`include "disciplines.vams"
module adc (out, in, clk);
	  parameter integer bits = 8 from [1:24];
	  parameter real fullscale = 1.0;
	  parameter real td = 0;
	  parameter real tt = 0;
	  parameter real vdd = 5.0;
	  parameter real thresh = vdd/2;
	  // resolution (bits)
	  // input range is from 0 to fullscale (V)
	  // delay from clock edge to output (s)
	  // transition time of output (s)
	  // voltage level of logic 1 (V)
	  // logic threshold level (V)
	  parameter integer dir = 1 from [-1:1] exclude 0;
	  // 1 for rising edges, 1 for falling
	  input in, clk;
	  output [0:bits-1] out;
	  voltage in, clk;
	  voltage [0:bits-1] out;
	  real sample, midpoint;
	  integer result[0:bits-1];
	  genvar i;
	  analog begin
		    @(cross(V(clk)-thresh, +1) or initial_step) begin
				sample = V(in);
				midpoint = fullscale/2.0;
				for(i = bits-1; i >= 0; i = i-1 ) begin
					  if(sample > midpoint) begin
						    result[i] = vdd;
						    sample = sample -  midpoint;
					  end else begin
						    result[i] = 0.0;
					  sample = 2.0*sample;
		    for (i = 0; i < bits; i = i + 1) begin
				V(out[i]) <+ transition(result[i], td, tt);
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: adc verilogA errors!
Reply #1 - Jun 25th, 2010, 7:17am
I would suggest using a later version of Cadence MMSIM, version 7.2 or later preferably. Lately Cadence have made some changes in the supported syntax for analog for loops and the use of genvars. Actually the restrictions they apply to array indexes are completely unnecessary and not supported by anything in the standard.
Cheers,
Marq
supermoment
Reply #2 - Jun 25th, 2010, 8:35am
do you have any workaround or methods other than using mmsim72??
Cry
Reply #3 - Jun 25th, 2010, 9:04am
supermoment wrote on Jun 25th, 2010, 8:35am:
Try to modify like following, although I don't know vendor's name of which you use simulator.
`define  Bits     8
       //parameter integer bits = 8 from [1:24];
       input in, clk;
       output [0:`Bits-1] out;
       voltage in, clk;
       voltage [0:`Bits-1] out;
       integer result[0:`Bits-1];
       genvar i;
       analog begin
                       sample = V(in);
                       for(i = `Bits-1; i >= 0; i = i-1 ) begin
                                       result[i] = vdd;
                               end else begin
                                       result[i] = 0.0;
               for (i = 0; i < `Bits; i = i + 1) begin
supermoment
Reply #4 - Jun 25th, 2010, 11:25pm
sorry, i  i posted the old version one.
The new version had fixed the "Bits" problem before the 1st post.
	  input in, clk;
	  voltage in, clk;
	  genvar i;
	  analog begin
				sample = V(in);
						    result[i] = vdd;
					  end else begin
						    result[i] = 0.0;
I got the same error message as in the first post.
It is related to the loop with "i"
I am using Cadence mmsim61.
supermoment
Reply #5 - Jun 26th, 2010, 12:40am
I have tried the method, but it does not work as well
line 6: "'<<-        -? define Bits 8"
line 26:        "output [0:'Bits<<--? -1] out;"
I am new in VerilogA.
Sounds like I could not use 'define Bits 8
I also tried the to use generate i;
in both cases ( with 'define Bits 8  or parameter interger Bits = 8 from [1:24];)
But it does not work at all...  :D
supermoment
Reply #6 - Jun 26th, 2010, 1:01am
Thanks a lot.
it works eventually..
The mistake i made was using ' instead of `
I learned the lesson.
Smiley
Reply #7 - Jun 26th, 2010, 1:16am
supermoment wrote on Jun 26th, 2010, 1:01am:
The mistake i made was using ' instead of `.
Simply you did same mistakes as the following.
http://www.designers-guide.org/Forum/YaBB.pl?num=1264401024/1#1
All threads after following are unnecessary.
http://www.designers-guide.org/Forum/YaBB.pl?num=1277453893/3#3
« Last Edit: Jun 26th, 2010, 9:28pm by pancho_hideboo »
