Jul 16th, 2024, 1:46pm
Linearity Sims (Read 2264 times)
Mayank
Linearity Sims
Jun 21st, 2010, 9:18pm
    If i want to check the linearity of my opamp, how do i determine what sims of the following or otherwise should i conduct ??
   THD /  Rapid IP3 / IM3 / IM2 / IM5 ??
Re: Linearity Sims
Reply #1 - Jun 24th, 2010, 5:52am
Mayank wrote on Jun 21st, 2010, 9:18pm:
It depends on application of OPAmp.
But THD and IP3 are enough for metrics of linearity generally, although I don't know what you mean by "Rapid IP3".
IP2(IM2) have various type. On the other hand IP3(IM3) definition is unique.
What type of IP2(IM2) do you intend to evaluate ?
See http://www.designers-guide.org/Forum/YaBB.pl?num=1262010975/1#1
Also see http://www.designers-guide.org/Forum/YaBB.pl?num=1264434513/1#1
« Last Edit: Jun 25th, 2010, 4:44am by pancho_hideboo »
Re: Linearity Sims
Reply #2 - Jun 24th, 2010, 7:48am
Mayank,
  If you mean Spectre RF Rapid IP3 analysis then it is really a
analysis rather than a measurement. It is probably better used
as a tool to
1) Debug where there is distortion in the design, along with the
   distortion summary
2) Identify the "worst-case" corners to investigate when you have a
   lot of corner conditions. Or the Monte Carlo seeds[runs] to
   investigate
  I would probably add Spurious Free Dynamic Range to the list of
measurements, if the target application is for data converters. One
other thing to consider for your list is test frequencies, loads, etc.
to be used for characterization.
