Dec 18th, 2025, 10:28pm
Modeling of Arbitrary Phase Shift in Verilog-A (Read 6987 times)
samiran
Jun 22nd, 2010, 10:41pm
Dear All,
I want to write a verilog-A code which provides an arbitrary phase shift (which can be controlled as a parameter) of the actual o/p signal.
Is there any in-built function already available to do so? If not, how can I achieve this?
Sam.
Re: Modeling of Arbitrary Phase Shift in Verilog-A
Reply #1 - Jun 24th, 2010, 7:26am
samiran wrote on Jun 22nd, 2010, 10:41pm:
No.
Synthesize aribitrary phase shifter using cascaded connected All-pass Filters.
http://en.wikipedia.org/wiki/All-pass_filter
Also see http://www.designers-guide.org/Forum/YaBB.pl?num=1233062253/1#1
Reply #2 - Jun 24th, 2010, 11:28am
You could use the absdelay() function. Unfortunately, Cadence's implementation does not work in the small-signal analyses. It has been that way for 14 years, so I guess they are not going to fix it.
It might help if you explained what you are trying to do. Verilog-A is a hardware description language, so it might help you to think about how you would implement this in hardware.
Reply #3 - Jun 24th, 2010, 11:38am
Ken Kundert wrote on Jun 24th, 2010, 11:28am:
I don't think absdelay() can be used as phase shifter.
Transfer function of absdelay() is exp(-j*ω*Tdelay).
So you can get only phase shift which changes linearly with frequency.
« Last Edit: Jun 25th, 2010, 4:05am by pancho_hideboo »
