Jul 20th, 2024, 1:21pm
The limitation of digital compensation circuit (Read 2025 times)
supermoment
Jun 23rd, 2010, 1:10am
A compensation circuit senses the delta difference between d+ & d- and then uses a DAC  to compensate d+ & d- until it has 101010 patterns at the comparator output (conventional digital compensation circuit).
The drawback of this circuit is that it does not know which compensation codes is the closest to the  zero difference (assume no glitch) since the analog value cannot be stored.
is there a way to know which code is the best code? the present code or the previous code?
vivkr
Re: The limitation of digital compensation circuit
Reply #1 - Jun 23rd, 2010, 1:56am
What you would need is either an analog correction circuit or a higher resolution digital correction circuit (which is "analog" for your coarse 1-bit corrector) parallel to the digital correction which you are using. This needs only a smaller range.
What are you trying to correct for by the way?
Vivek
Mayank
Reply #2 - Jun 23rd, 2010, 3:51am
Forget what is closest to the Actual Value. This is the funda of Digital Calibration.
You set your resolution acc. to max. error you can tolerate.
After that, you just have to accept one or two bit error depending on your scheme.
Resolving / Rounding off final code requires Delta/2 comparison, which again means higher resolution either in analog OR Digital cktry --> Hardware Overhead.
supermoment
Reply #3 - Jun 23rd, 2010, 4:23am
exactly same as what I was thinking...
Grin
