Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 19
th
, 2024, 1:29pm
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› About monte carlo analysis
Previous topic
Next topic
About monte carlo analysis (Read 4680 times)
wunderkind
oregon
Jun 24
th
, 2010, 11:15am
I want to simulate the offset of a comparator and want to follow the way mentioned in this document:
http://www.designers-guide.org/Analysis/comparator.pdf
However, i don't know how to store the comparator's results into a file. I used the sampler found in designer's guide community, the link is:
http://www.designers-guide.org/VerilogAMS/functional-blocks/smplr/sampler.vams
But the problem is the content of the file will be replaced each time when one run of Monte Carlo analysis is finished so that I can only get the comparator's results for the last run of Monte Carlo analysis.
I am just wondering how to store all comparator's results.
Thank you
IP Logged
Re: About monte carlo analysis
Reply #1 -
Jun 24
th
, 2010, 11:21am
wunderkind wrote
on Jun 24
th
, 2010, 11:15am:
It depends on what simulator you use.
What simulator do you use ?
Show me netlist regarding analysis statements including monte carlo analysis.
Kita━━━━━━(゚∀゚)━━━━━━ !!!!!
http://www7.plala.or.jp/ungeromeppa/flash/kita.html
http://www.youtube.com/watch?v=mjIxGh55bMM&feature=related
IP Logged
wunderkind
oregon
Reply #2 -
Jun 24
th
, 2010, 11:25am
pancho_hideboo wrote
on Jun 24
th
, 2010, 11:21am:
wunderkind wrote
on Jun 24
th
, 2010, 11:15am:
The simulator I use is Cadence Spectre
IP Logged
Reply #3 -
Jun 24
th
, 2010, 11:30am
wunderkind wrote
on Jun 24
th
, 2010, 11:25am:
Set "savefamilyplots=yes" in montecarlo analysis statement.
IP Logged
wunderkind
oregon
Reply #4 -
Jun 24
th
, 2010, 1:46pm
on Jun 24
th
, 2010, 11:30am:
wunderkind wrote
on Jun 24
th
, 2010, 11:25am:
I have tried this, but it doesn't work
IP Logged
Reply #5 -
Jun 25
th
, 2010, 3:57am
wunderkind wrote
on Jun 24
th
, 2010, 1:46pm:
If you see result's data by using "Results Browser", there are many result's data.
Do you use correct data which include all trial data in monte carlo ?
IP Logged
wunderkind
oregon
Reply #6 -
Jun 28
th
, 2010, 4:03pm
on Jun 25
th
, 2010, 3:57am:
wunderkind wrote
on Jun 24
th
, 2010, 1:46pm:
I have solved my problem by modifying the sentence of "file = $fopen(filename)" to "file = $fopen(filename, "a")" in the VerilogA for sampler. In such a way that I can get all Monte Carlo simulation results
IP Logged
wunderkind
oregon
Reply #7 -
Jun 28
th
, 2010, 4:04pm
on Jun 25
th
, 2010, 3:57am:
wunderkind wrote
on Jun 24
th
, 2010, 1:46pm:
Thank you very much, pancho_hideboo!!
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
