Jul 19th, 2024, 7:25pm
Process independent Bias Current Generation (Read 2800 times)
despap
Jun 24th, 2010, 11:40pm
What is the best way to generate a process independent bias current, given that extenral resistor is not available and very accurate bandgap reference is available( untrimmed 6sigma of 2.5%).
Thanks for any help.
raja.cedt
Re: Process independent Bias Current Generation
Reply #1 - Jun 28th, 2010, 2:06am
hi,
  where you need such high accuracy?
Thanks.
despap
Reply #2 - Jun 28th, 2010, 2:25am
I need bias current accurate to +/- 10% .. and i have bandgap ref of 2.5%6 sigma accurate.
Vladislav D
The Netherlands
Reply #3 - Jun 28th, 2010, 11:32am
despap wrote on Jun 24th, 2010, 11:40pm:
I think, no ways to design current source independed on corners without trimming or offchip resistors. Furthermore, I don't see a reason to do such sources. It may be even dangerous if all devices go in one direction due to a corner,whereas a current source keeps a constant value of current. A circuit might leave the "right" bias.  What really need is to keep low variations due to statististical mismatches.
