Aug 16th, 2024, 10:34pm
LC VCO buffer (Read 4234 times)
supermoment
LC VCO buffer
Jun 29th, 2010, 7:54am
Could I directly connect CML buffer to the output of LC VCO tank?
If the CML buffer is too strong, it might couple back to the VCO tank.
The alternative is to use ac couple to CML buffer. however it reduces the output amplitude and the tuning range.
What is the common practice?
rfcooltools.com
Re: LC VCO buffer
Reply #1 - Jun 29th, 2010, 11:09am
Aside from amplitude possibly being to large
Most of the time fixed capacitance reduction on the tank is the target.  so ac coupling is almost always used to reduce this.
http://rfcooltools.com
supermoment
Re: LC VCO buffer
Reply #2 - Jul 5th, 2010, 2:23am
ac couple might introduce additional loss to the tank if the R after the ac cap is too low....
rfcooltools.com
Re: LC VCO buffer
Reply #3 - Jul 6th, 2010, 10:01pm
depends on the capacitance
If the cap is small then the resistance will be weighted accordingly.
love_analog
Re: LC VCO buffer
Reply #4 - Jul 29th, 2010, 6:30am
Remember that ac coupling cap has parasitics to ground so you're amplitude will become lower before it hits your buffer.
Also the ac coupling cap will reduce your freq of oscillation which will be compensated by Cbank or vctl on VCO
loveanalog.blogspot.com
The Power of Analog
