Jul 18th, 2024, 10:03pm
How long should bypass gate cap be? (Read 5818 times)
RobG
Bozeman, MT
Jul 09th, 2010, 9:23pm
I've always had a rule of thumb of not making gate caps longer than 10um. I have forgotten why, which happens more as I age. I think it was the n-well resistance that was in series with the cap. Anyone have a rule of thumb these days? I'm bypassing/decoupling power supplies in a 0.18u process and it would be better if I could use L=16u.
rg
neoflash
Mixed-Signal
Designer
Re: How long should bypass gate cap be?
Reply #1 - Jul 15th, 2010, 10:54am
This is not a well-defined question.
The longer the channel the larger the ESR. But the tolerance should depend on your requirement.
Reply #2 - Jul 16th, 2010, 2:42am
Yes, I agree with neoflash. The channel length or ESR depends on your requirement. Sometimes you even need larger ESR to kill the ringing caused by bonding wire.
RobG
Bozeman, MT
Reply #3 - Jul 16th, 2010, 8:59am
Thanks for the feedback... I know it depends on the requirements, but what I'm not quite sure of is how would one create a model of a MOS cap that includes the effects of longer channel length. I do not think current models include this effect. Is it the Nwell resistance under the gate that causes the increase in ESR?
neoflash
Mixed-Signal
Designer
Reply #4 - Jul 16th, 2010, 10:19am
If you are using nmoscap, the answer is yes. The nmos is the dominant source. (Some from the gate too.)
RobG
Bozeman, MT
Reply #5 - Jul 16th, 2010, 11:08am
Actually I'm just using a pmos transistor since I'm not up to making a nmos over nwell cap. The rules are incredibly screwed up in this process and I have no time....
OK, that is what I thought. I just wanted to make sure it wasn't some funny physics... I was raised a bipolar man...
I just want to confirm.
Say you had a W=10, L=10 transistor with Cgs=10fF/um^2. Nwell sheet resistance is 1k-ohm/sq. The total cap would be 1pF and Res=1k.  So a first order model would be three pmos (1/3pF) and two 500 ohm resistors (RC lumped element). The gates tied to vdd (ignoring poly R) and the sources would be distributed between the 500 ohm resistors: One going to the middle and the other two going to the ends which would be tied to vss.
neoflash
Mixed-Signal
Designer
Reply #6 - Jul 16th, 2010, 11:28am
If a PMOS used and it is turned-on with bias condition, you don't worry about N-well resistance. Because the ESR consists of only the p-channel resistance and gate poly. N-well is shielded by the channel so no impact on the ESR.
RobG
Bozeman, MT
Reply #7 - Jul 16th, 2010, 12:00pm
lol... I just looked it up in razavi's book, page 622. It is just channel resistance ~1/gm and the time constant is proportional to L^2.
neoflash
Mixed-Signal
Designer
Reply #8 - Jul 16th, 2010, 12:04pm
No. It is not related with gm, instead it is propotional to gds.
RobG
Bozeman, MT
Reply #9 - Jul 16th, 2010, 12:36pm
gm is a little low for a device with no dc current, eh?  ~1/L/(Vgs-Vt) is what I was getting at. I'm doing layout which means I can, and did, leave my brain at home.
Anyway, why is this different for an nmos in an Nwell?
