Jul 17th, 2024, 12:39pm
frequency detector and adjustor (Read 2899 times)
supermoment
Jul 11th, 2010, 12:03am
I built a verilogA code to work as frequency detector and adjustor for my phase loop which has pretty small BW. I do not have frequency loop yet.
here is the code without compilation problem. However, it has a problem to simulate due to zero diagonal Jacobian..
It is because the adjustout signal  issue I think.
When lock is asserted, the cell needs to follow the vctrl (adjustout signal).
when lock event =1
do this --> adjust = V(adjustout);
else do this
V(adjustout) <+ adjust;
I have tried other method like using case(lock)..
it gave me the same problem
the code work well if commenting out the adjust = V(adjustout).
but the adjust voltage could be very different to vctrl(adjustout)
`include "constants.vams"
`include "disciplines.vams"
module freq_meas_lock(clk, freqout, adjustout, lockout, vcm, lockoutdelay);
	  parameter real vcc =2 from (0:inf);
	  parameter real freqin =5e9 from (0:inf);
	  parameter real freqscale=5e9 from (0:inf);
	  parameter real ppm=1000  from (0:inf);   //ppm=500->0.05% of the freq
	  parameter integer dir = +1 from [-1:+1] exclude 0;
	  parameter real adjust_start = 1.2  from (0:inf) ;
	  parameter real adjust_step = 1e-3  from (0:inf) ;
	  parameter real delay =1000e-12  from (0:inf);
	  inout   adjustout;
	  input   clk, vcm ;
	  output  freqout, lockout,lockoutdelay;
	  real    current_time, last_time, freq, adjust  ;
	  integer cross_cnt, lock ;
	  voltage clk, freqout, adjustout,lockout, vcm,lockoutdelay;
	  analog begin
		    @( initial_step ) begin
				cross_cnt=0;
				last_time=0;
				current_time=0;
				freq=freqin/freqscale;
				V(adjustout) <+ adjust_start;
				adjust = adjust_start;
				lock=0;
		    @(cross(V(clk)-V(vcm), dir, 1, clk.potential.abstol)) begin
				cross_cnt = cross_cnt + 1;
				last_time = current_time;
				current_time = $abstime;
				if (freq<1-ppm/1e6) begin
					  adjust = adjust + adjust_step ;
					  lock = 0;
				else if(freq>1+ppm/1e6) begin
					  adjust =  adjust - adjust_step ;
					  lock = 0;
				else begin
					  lock = 1;
		    if (cross_cnt <  2) begin
		    else begin
				freq=(1/(current_time-last_time))/freqscale;
		    V(freqout) <+ freq;
		    V(lockout) <+vcc*lock;
		    V(lockoutdelay) <+vcc*transition(lock ? 1: 0, delay,10p,10p);
Re: frequency detector and adjustor
Reply #1 - Jul 12th, 2010, 6:11am
supermoment wrote on Jul 11th, 2010, 12:03am:
when lock event =1
else do this
When lock event != 1, what is the value of "adjust" ?  Is is supposed to just remember the last value that it grabbed during a lock event?
When lock event == 1, you have
which is circular.  Perhaps you need to have an input adjustin, so that
 @(cross (...))
   adjust = V(adjustin); // sample
Then connect adjustout and adjustin externally (in the netlist), perhaps with a resistor.
supermoment
Reply #2 - Jul 12th, 2010, 6:21am
i have tried that before by adding another input port adjustin
BUT it has the same warning because at the schematic level, the adjustin & adjustout is shorten when lock=1. I added an ideal switch (lock=1, connect adjustin to adjustout; else lock=0, open.
the adjust value when lock!=1 is following the transistor level phase-loop. Hence i cannot use the last value. The value must be updated.
i write that code to work as a frequency loop cos i do not have the schematic yet.
Is there a workaround code to adjust vctrl?
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #3 - Jul 12th, 2010, 8:04am
It really depends on what you have connected to the adjustout pin. If it is a voltage source you will get a zero diagonal problem as the value cannot be resolved by both the model and the vsource driving at the same time. Using a resistor in series with this vsource might help although you may encounter voltage loop warnings.
The contribution statement inside the @(initial_step) is not necessary: there is already a similar contribution statement outside it.
Marq
