Jul 18th, 2024, 11:23pm
Concern of connecting thin-oxide device to ground/power (Read 1506 times)
neoflash
Mixed-Signal
Designer
Jul 15th, 2010, 9:51am
In sub-130nm process, tsmc requested to use tie-high tie-low for soft connection to power/gnd bus.
Not sure what kind of issue is getting worried? CDM, HBM, or CMP during manufacturing?
carlgrace
Berkeley, CA
Re: Concern of connecting thin-oxide device to ground/power
Reply #1 - Jul 15th, 2010, 3:33pm
They are worried about all three.  Also, overvoltages due to current faults on the supply are possible.  The tie cells are small, go ahead and use them!
