Jul 18th, 2024, 7:29am
PLL basic question. (Read 3301 times)
raja.cedt
PLL basic question.
Jul 17th, 2010, 3:08am
i have a basic question on PLL,
1.is it really locking phase locking or frequency locking. i feel it is making phase difference  between ref and fb clock is constant at some value (normally it is zero), so frequency locking is happening. If so why Frequency Lock loop.
2. In loop filter we have RC series branch, in that r is doing phase lock and c is doing frequency locking, is this correct?
Rajasekhar.
buddypoor
Bremen, Germany
Re: PLL basic question.
Reply #1 - Jul 17th, 2010, 3:47am
raja.cedt wrote on Jul 17th, 2010, 3:08am:
Rajasekhar.
1.) Of course, it depends on the kind of PD you are using.
In any case, when frequencies are different, it's a kind of frequency locking (pull-in process); if this is completed, phase locking takes over until the differece beween both phases is roughly constant (not always zero, dpends on PD).
2.) I don't understand the question. The rc combination is afilter which must attenuate unwanted products out of the PD.
raja.cedt
Reply #2 - Jul 17th, 2010, 4:21am
hi buddypoor,
thanks for your ans. what i mean  is in case loop filter with no shunt cap, there will be on RC series circuit, so resister is kind of proportional gain and cap is a kind of integral gain. So integral  controller will change the frequency means cap will set the frequency. proportional controller will change the phase so resister will set phase.
Thanks.
tkhan
Reply #3 - Jul 17th, 2010, 6:22am
Read Razavi's analog book chapter 15, it has a good explanation of the concepts you are interested in.
Mayank
Reply #4 - Jul 18th, 2010, 8:53pm
+1 at tkhan
In a Locked State, Frequency's gotta b same as Fcomparison if you want a constant Phase Diff. / Phase Lock.
[quote]
The ZERO from series RC provides proportional gain, while the Pole from C provides the integral gain. Nothing further.
--M
love_analog
Reply #5 - Jul 29th, 2010, 6:37am
Raja
You are partially correct.
The cap acts as in integrator so it stores the frequency difference. In reality, if there was no stability thing you could just use a cap. Remember, DLL Smiley
The resistor is a memory-less element not an accumulator.
loveanalog.blogspot.com
The Power of Analog
