Jul 16th, 2024, 6:36am
problem with detecting falling edge (Read 2360 times)
mowiehowie
Jul 22nd, 2010, 7:00am
hi all.
i need to detect a falling edge in order to count it and generate a signal. i've made a code like this:
analog begin
     @(initial_step) begin
           cycle = 0;
           carrega = 0;
           k = 0;
           serial = 0;
           vth = 0.9*V(dvdd,dgnd);
     @(cross(V(clk)-vth, 1)) begin
           if (cycle < 71)      cycle = cycle + 1; $strobe(cycle);
           if (cycle <= 70) serial = $table_model(cycle, "testvector.dat", "D");
           if (cycle == 71) cycle = 0;
     @(cross(V(clk)-vth, -1)) begin
           if (k < 71) k = k + 1;  $strobe(k);
           if (k == 71) carrega = 1; k = 0;
     V(out_d,dgnd) <+ serial*V(dvdd,dgnd);
     V(load,dgnd) <+ carrega*V(dvdd,dgnd);
in fact, i can see that the rising edge is detected properly but the falling edge is not. k only reaches '1'. it doesnt increase anymore.
what might be going on?
Re: problem with detecting falling edge
Reply #1 - Jul 22nd, 2010, 12:12pm
A stupid trick for checking this might be to change
to this:
@(cross(vth-V(clk), 1)) begin
