Dec 13th, 2025, 11:18am
cannot filter out short pulses (Read 1315 times)
Pavel
Lausanne/Switzerland
Jul 27th, 2010, 12:50am
I want my latch to filter out short pulses (shorter than 0.15ns).
But in spite of standard it doesn't. Here is code:
`timescale 1 ns / 1 ps
module Latch(nD, nGate, Q);
  input nD, nGate;
  output reg Q;
  always @(nGate, nD)
      if(nGate == 0) Q <= ~nD;
      else Q <= Q;
  specify
      specparam tRise_nGate_Q = 0.15, tFall_nGate_Q = 0.2;
      (negedge nGate *> (Q+:nD)) = (tRise_nGate_Q, tFall_nGate_Q);
  endspecify
Where is my mistake ?
Pavel.
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: cannot filter out short pulses
Reply #1 - Aug 3rd, 2010, 7:17am
You might want to have a look at the PATHPULSE$ specparam (section 14.6.1 of the 1364-2005 IEEE Verilog LRM) which explains how to filter out short pulses with the specify block.
Cheers,
Marq
Reply #2 - Aug 3rd, 2010, 10:37am
I tend to use the inertial delay of the continuous assignment statement to filter out short pulses. You might want to try that.
