Aug 16th, 2024, 11:42am
Cadence Convergence Error (Read 4217 times)
mohammadreza
Jul 27th, 2010, 4:25am
I am simulating an RF Power Amplifier in Cadence, SpectreRF environment. I am controlling the supply current by a seperate voltage applied to a transistor. For some values that I choose, I face with convergence error, both in PSS and Transient. However, when I remove my mathcihng network and replace it by a real load value that I had designed, I face no errors.
Is there any way for setting the options correctly so that I don't lose accuracy and have my expected result? I have tried the Moderate and ven liberal presets but the moderate one faces error as well and the liberal one is completely away.
mohammadreza
Re: Cadence Convergence Error
Reply #1 - Jul 27th, 2010, 5:08am
Thanks, I didn't see any HB-engine. Just shooting and flexible balance. I chose flexible balance and it worked.
About the Q, since I need to operate between 2.4GHz and 2.49GHz, I chose 300. Is that fine?
thanks
mohammadreza
Reply #2 - Jul 27th, 2010, 5:29am
thanks!
decreasing the Q helped run the simulation successfully with the moderate accuracy.
Reply #3 - Jul 27th, 2010, 7:16am
pancho_hideboo wrote on Jul 27th, 2010, 4:30am:
Maybe your matching network has very high Q.
High Q could cause convergence failure for time domain solver.
Use HB-engine not Shooting-Newton-engine in PSS of Cadence Spectre.
mohammadreza wrote on Jul 27th, 2010, 5:08am:
See http://www.designers-guide.org/Forum/YaBB.pl?num=1258711290/1#1
Is that fine?
BW3dB=f0/Q=2.445GHz/300=8.15MHz. It is too narrow.
You have to have broad BW3dB which is far broader than 90MHz.
So set Q lesser than 27.
Also see the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1207009725/2#2
http://www.designers-guide.org/Forum/YaBB.pl?num=1278414763/18#18
mohammadreza wrote on Jul 27th, 2010, 5:29am:
Your case summaries are followings.
For Q>=300, Shooting-Newton-PSS with accuracy of moderate can not converge.
For Q<30, Shooting-Newton-PSS with accuracy of moderate can converge.
For Q>=300, HB-PSS with accuracy of moderate can converge.
For Q<30, HB-PSS with accuracy of moderate can converge.
Are the aboves correct ?
« Last Edit: Jul 28th, 2010, 6:28am by pancho_hideboo »
mohammadreza
Reply #4 - Jul 28th, 2010, 5:41am
Yes, that's right
