Jul 17th, 2024, 12:43pm
Verilog-A code for charge pump (Read 8314 times)
vp1953
Jul 29th, 2010, 4:14pm
I am looking for verilogA code to implement a charge pump (used in PLLs). The default code available in Cadence seems to be very unrealistic in that even when the output voltage is at ground or supply, current continues to be sunk/sourced resulting in substantial build of voltage.
I did not find any code for a charge pump at the designers guide site (it has code for pretty much everything else).
Thank you in advance!
Re: Verilog-A code for charge pump
Reply #1 - Jul 31st, 2010, 10:38am
Take a look at http://www.designers-guide.org/VerilogAMS/functional-blocks/pfd_cp/pfd_cp.va. I have updated the PFD/CP on this site to include an output clamp that limits the output voltage to the rails.
vp1953
Reply #2 - Aug 2nd, 2010, 11:25am
Hi Ken,
Thanks a million! It is greatly appreciated.
